ViewportOn 属性 (ActiveX)
指定视口的显示状态。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论若要打开或关闭视口的显示控件,请使用该方法。Display 例子VBA: Sub Example_ViewportOn()
' This example creates two new paper space viewports.
' It then checks the status of the viewports.
Dim pviewportObj1 As AcadPViewport
Dim pviewportObj2 As AcadPViewport
Dim center(0 To 2) As Double
Dim width As Double
Dim height As Double
' Define the paper space viewport
center(0) = 3: center(1) = 3: center(2) = 0
width = 10
height = 10
' Change from model space to paper space
ThisDrawing.ActiveSpace = acPaperSpace
' Create the paper space viewports
Set pviewportObj1 = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
center(0) = 8: center(1) = 8: center(2) = 0
width = 10
height = 10
Set pviewportObj2 = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
' Before making a paper space viewport active,
' the mspace property needs to be True
pviewportObj1.DISPLAY (True)
ThisDrawing.mspace = True
ThisDrawing.ActivePViewport = pviewportObj1
MsgBox "pviewportObj1 is " & (IIf(pviewportObj1.ViewportOn, "on.", "not on.")) & vbCrLf & _
"pviewportObj2 is " & (IIf(pviewportObj2.ViewportOn, "on.", "not on."))
' Now turn on pviewportObj2 as well
pviewportObj2.DISPLAY (True)
可视化 LISP: (vl-load-com)
(defun c:Example_ViewportOn()
;; This example creates two new paper space viewports.
;; It then checks the status of the viewports.
;; Define the paper space viewport
(setq center (vlax-3d-point 3 3 0)
width 10
height 10)
;; Change from model space to paper space
(vla-put-ActiveSpace doc acPaperSpace)
;; Create the paper space viewports
(setq paperSpace (vla-get-PaperSpace doc))
(setq pviewportObj1 (vla-AddPViewport paperSpace center width height))
(setq center (vlax-3d-point 8 8 0)
width 10
height 10)
(setq pviewportObj2 (vla-AddPViewport paperSpace center width height))
;; Before making a paper space viewport active,
;; the mspace property needs to be True
(vla-Display pviewportObj1 :vlax-true)
(vla-put-MSpace doc :vlax-true)
(vla-put-ActivePViewport doc pviewportObj1)
(alert (strcat "pviewportObj1 is " (if (= (vla-get-ViewportOn pviewportObj1) :vlax-true) "on." "not on.")
"\npviewportObj2 is " (if (= (vla-get-ViewportOn pviewportObj2) :vlax-true) "on." "not on.")))
;; Now turn on pviewportObj2 as well
(vla-Display pviewportObj2 :vlax-true)
GMT+8, 2026-10-28 03:05
