ViewportDefault 属性 (ActiveX)
指定是否要在新视口中冻结图层。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_ViewportDefault()
' This example creates a new layer called "New_Layer". It then uses
' the ViewportDefault property of each Layer to display whether or not that layer
' is frozen in new viewports. The user has the ability to toggle whether or not
' each layer will be frozen in new viewports, and the final ViewportDefault status
' for all layers is displayed.
Dim layerObj As AcadLayer, tempLayer As AcadLayer
Dim msg As String
' Add the layer to the layers collection
Set layerObj = ThisDrawing.Layers.Add("New_Layer")
' Make the new layer the active layer for the drawing
ThisDrawing.ActiveLayer = layerObj
' Cycle through the layers and allow user to make them frozen in new viewports or not
For Each tempLayer In ThisDrawing.Layers
If tempLayer.ViewportDefault Then ' Determine if this layer is fozen in new viewports
If MsgBox("The layer '" & tempLayer.name & "' will be frozen in new viewports. Would you like to make this layer unfrozen in new viewports?", vbYesNo & vbQuestion) = vbYes Then
tempLayer.ViewportDefault = False ' Change frozen state
End If
Else
If MsgBox("The layer '" & tempLayer.name & "' will not be frozen in new viewports. Would you like to make this layer frozen in new viewports?", vbYesNo & vbQuestion) = vbYes Then
tempLayer.ViewportDefault = True ' Change frozen state
End If
End If
Next
' Display the new viewport freeze status of the layers in this drawing
' Determine if this layer is frozen in new viewports
msg = msg & "The layer '" & tempLayer.name & "' will be frozen in new viewports." & vbCrLf
Else
msg = msg & "The layer '" & tempLayer.name & "' will not be frozen in new viewports." & vbCrLf
End If
Next
MsgBox msg
可视化 LISP: (vl-load-com)
(defun c:Example_ViewportDefault()
;; This example creates a new layer called "New_Layer". It then uses
;; the ViewportDefault property of each Layer to display whether or not that layer
;; is frozen in new viewports. The user has the ability to toggle whether or not
;; each layer will be frozen in new viewports, and the final ViewportDefault status
;; for all layers is displayed.
;; Add the layer to the layers collection
(setq layerObj (vla-Add (vla-get-Layers doc) "New_Layer"))
;; Make the new layer the active layer for the drawing
(vla-put-ActiveLayer doc layerObj)
;; Cycle through the layers and allow user to make them frozen in new viewports or not
(vlax-for tempLayer (vla-get-Layers doc)
;; Display the current new viewports layer state
(if (= (vla-get-ViewportDefault tempLayer) :vlax-true)
(alert (strcat "The layer '" (vla-get-Name tempLayer) "' is frozen for new viewports. Toggling state now."))
(alert (strcat "The layer '" (vla-get-Name tempLayer) "' is not frozen for new viewports. Toggling state now."))
(vla-put-ViewportDefault tempLayer (if (= (vla-get-ViewportDefault tempLayer) :vlax-true) :vlax-false :vlax-true))
;; Display the new viewport freeze status of the layers in this drawing
(setq msg "")
;; Determine if this layer is frozen in new viewports
(setq msg (strcat msg "The layer '" (vla-get-Name tempLayer) "' will be frozen in new viewports.\n"))
(setq msg (strcat msg "The layer '" (vla-get-Name tempLayer) "' will not be frozen in new viewports.\n"))
(alert msg)
GMT+8, 2026-10-28 02:19
