UnitsFormat 属性 (ActiveX)
指定除角度之外的所有尺寸的单位格式。 支持的平台:仅限 Windows 签名VBA: object.UnitsFormat
属性值只读:不 类型:枚举acDimLUnits
言论此属性的初始值为 。acDimLDecimal 如果此属性设置为 ,则 和 属性指定的格式将用于设置十进制值的格式。acDimLDecimalDecimalSeparatorPrimaryUnitsPrecision 若要创建堆叠体系结构或分数单位格式,请使用该属性。FractionFormat 注意:此属性将覆盖给定维度的 DIMLUNIT 系统变量的值。
例子VBA: Sub Example_UnitsFormat()
' uses UnitsFormat to cycle through some common unit formats
' for the dimension
Dim dimObj As AcadDimAligned
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
' Cycle through common unit formats
dimObj.UnitsFormat = acDimLScientific ' Change format to Scientific
MsgBox "The dimension units are now set to Scientific"
dimObj.UnitsFormat = acDimLDecimal ' Change format to Decimal
MsgBox "The dimension units are now set to Decimal"
dimObj.UnitsFormat = acDimLArchitectural ' Change format to Architectural
MsgBox "The dimension units are now set to Architectural"
dimObj.UnitsFormat = acDimLWindowsDesktop ' Change format to WindowsDesktop
MsgBox "The dimension units are now set to Windows Desktop"
可视化 LISP: (vl-load-com)
(defun c:Example_UnitsFormat()
;; uses UnitsFormat to cycle through some common unit formats
;; for the dimension
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5.12345678 5 0)
(vla-ZoomAll acadObj)
;; Cycle through common unit formats
(vla-put-UnitsFormat dimObj acDimLScientific) ;; Change format to Scientific
(alert "The dimension units are now set to Scientific")
(vla-put-UnitsFormat dimObj acDimLDecimal) ;; Change format to Decimal
(alert "The dimension units are now set to Decimal")
(vla-put-UnitsFormat dimObj acDimLArchitectural) ;; Change format to Architectural
(alert "The dimension units are now set to Architectural")
(vla-put-UnitsFormat dimObj acDimLWindowsDesktop) ;; Change format to WindowsDesktop
(alert "The dimension units are now set to Windows Desktop")
GMT+8, 2026-10-27 16:49
