UCSIconAtOrigin 属性 (ActiveX)
指定是否在原点显示 UCS 图标。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论如果 UCS 图标处于打开状态(请参阅属性)且未显示在原点,则该图标将显示在 UCSORG 系统变量定义的 WCS 坐标处。UCSIconOn 例子VBA: Sub Example_UCSIconAtOrigin()
' This example toggles the setting of UCSIconAtOrigin.
Dim viewportObj As AcadViewport
' Set the viewportObj variable to the activeviewport
Set viewportObj = ThisDrawing.ActiveViewport
' Make sure the UCS Icon is on, and a new UCS is defined.
' The new UCS defines the origin for the icon. When the icon
' is not displayed at the origin, it is displayed at the
' lower-left corner of the display.
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPoint(0 To 2) As Double
Dim yAxisPoint(0 To 2) As Double
origin(0) = 2: origin(1) = 2: origin(2) = 0
xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
ThisDrawing.ActiveUCS = ucsObj
viewportObj.UCSIconOn = True
' Display the current setting of UCSIconAtOrigin
MsgBox "UCSIconAtOrigin is: " & IIf(viewportObj.UCSIconAtOrigin, "On", "Off"), , "UCSIconAtOrigin Example"
' Toggle the setting of UCSIconAtOrigin
viewportObj.UCSIconAtOrigin = Not (viewportObj.UCSIconAtOrigin)
' Reset the active viewport to see the change
ThisDrawing.ActiveViewport = viewportObj
MsgBox "UCSIconAtOrigin is now: " & IIf(viewportObj.UCSIconAtOrigin, "On", "Off"), , "UCSIconAtOrigin Example"
可视化 LISP: (vl-load-com)
(defun c:Example_UCSIconAtOrigin()
;; This example toggles the setting of UCSIconAtOrigin.
;; Set the viewportObj variable to the activeviewport
(setq viewportObj (vla-get-ActiveViewport doc))
;; Make sure the UCS Icon is on, and a new UCS is defined.
;; The new UCS defines the origin for the icon. When the icon
;; is not displayed at the origin, it is displayed at the
;; lower-left corner of the display.
(setq origin (vlax-3d-point 2 2 0)
xAxisPoint (vlax-3d-point 3 2 0)
yAxisPoint (vlax-3d-point 2 3 0))
(setq ucsObj (vla-Add (vla-get-UserCoordinateSystems doc) origin xAxisPoint yAxisPoint "UCS1"))
(vla-put-ActiveUCS doc ucsObj)
(vla-put-UCSIconOn viewportObj :vlax-true)
;; Display the current setting of UCSIconAtOrigin
(alert (strcat "UCSIconAtOrigin is: " (if (= (vla-get-UCSIconAtOrigin viewportObj) :vlax-true) "On" "Off")))
;; Toggle the setting of UCSIconAtOrigin
(vla-put-UCSIconAtOrigin viewportObj (if (= (vla-get-UCSIconAtOrigin viewportObj) :vlax-true) :vlax-false :vlax-true))
;; Reset the active viewport to see the change
(vla-put-ActiveViewport doc viewportObj)
(alert (strcat "UCSIconAtOrigin is now: " (if (= (vla-get-UCSIconAtOrigin viewportObj) :vlax-true) "On" "Off")))
GMT+8, 2026-10-26 19:52
