TrueColorImages 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 721| 评论: 0|原作者: admin|来自: AutoCAD
确定光栅和渲染图像是以真彩色还是托盘化颜色显示。
object.TrueColorImages
类型:首选项显示
此属性应用于的对象。
只读:不
类型:布尔
  • True:以操作系统能够实现的最高颜色分辨率显示光栅和渲染图像。
  • False:以调色板颜色显示光栅和渲染图像。
此属性的初始值为 False。
Sub Example_TrueColorImages()
    ' This example reads and modifies the preference value which determines
    ' if raster and render images are displayed at True Color or palletized color.
    ' When finished, this example resets the preference value back to
    ' it's original value.
    ' This example uses the "2d Projected Polylines.jpg" found in the sample
    ' directory. If you do not have this image, or it is located
    ' in a different directory, insert a valid path and file name
    ' for the imageName variable below.
    Dim ACADPref As AcadPreferencesDisplay
    Dim scalefactor As Double, rotationAngle As Double
    Dim imageName As String
    Dim rasterObj As AcadRasterImage
    imageName = "c:\AutoCAD\sample\2d Projected Polylines.jpg"
    ' Define Raster object
    insertionPoint(0) = 5: insertionPoint(1) = 5: insertionPoint(2) = 0
    scalefactor = 5#: rotationAngle = 0
    On Error GoTo ERRORTRAP
    ' Loads a raster image into model space
    Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Display
    originalValue = ACADPref.TrueColorImages
    MsgBox "The TrueColorImages preference is set to: " & originalValue
    ' Modify the TrueColorImages preference by toggling the value
    ACADPref.TrueColorImages = Not (originalValue)
    newValue = ACADPref.TrueColorImages
    MsgBox "The TrueColorImages preference has been set to: " & newValue
    ' Reset the preference back to it's original value
    '         this preference in effect
    ACADPref.TrueColorImages = originalValue
    MsgBox "The TrueColorImages preference was reset back to: " & originalValue
    Exit Sub
    ' If you got an error (most likely a problem with the file path),
    ' then display an error message
ERRORTRAP:
    If Err.Description <> "" Then
        MsgBox Err.Description
    End If
(defun c:Example_TrueColorImages()
    ;; This example reads and modifies the preference value which determines
    ;; if raster and render images are displayed at True Color or palletized color.
    ;; When finished, this example resets the preference value back to
    ;; it's original value.
    ;; This example uses the "2d Projected Polylines.jpg" found in the sample
    ;; directory. If you do not have this image, or it is located
    ;; in a different directory, insert a valid path and file name
    ;; for the imageName variable below.
    ;; Define Raster object
    (setq insertionPoint (vlax-3d-point 5 5 0)
          imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
          scalefactor 5
          rotationAngle 0)
    (if (/= (findfile imageName) nil)
        (progn
            ;; Creates a raster image in model space
            (setq raster (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotationAngle))
            (vla-ZoomExtents acadObj)
            ;; Get the display preferences object
            (setq ACADPref (vla-get-Display (vla-get-Preferences acadObj)))
            (setq originalValue (vla-get-TrueColorImages ACADPref))
            (alert (strcat "The TrueColorImages preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
            ;; Modify the TrueColorImages preference by toggling the value
            (vla-put-TrueColorImages ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
            (alert (strcat "The TrueColorImages preference has been set to: " (if (= (vla-get-TrueColorImages ACADPref) :vlax-true) "True" "False")))
            ;; Reset the preference back to it's original value
            ;;         this preference in effect
            (vla-put-TrueColorImages ACADPref originalValue)
            (alert (strcat "The TrueColorImages preference was reset back to: " (if (= (vla-get-TrueColorImages ACADPref) :vlax-true) "True" "False")))
        (alert (strcat imageName " could not be found."))
GMT+8, 2026-11-15 13:43
