TranslateIDs 属性 (ActiveX)
指定在 deepClone 或 wblockClone 操作期间转换任何包含的对象 ID。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_TranslateIDs()
' This example creates a new XRecord if one doesn't exist,
' and toggles the setting for TranslateIDs
Dim TrackingDictionary As AcadDictionary, TrackingXRecord As AcadXRecord
Dim XRecordDataType As Variant, XRecordData As Variant
Dim ArraySize As Long, iCount As Long
Dim DataType As Integer, Data As String, msg As String
' Unique identifiers to distinguish our XRecordData from other XRecordData
Const TYPE_STRING = 1
Const TAG_DICTIONARY_NAME = "ObjectTrackerDictionary"
Const TAG_XRECORD_NAME = "ObjectTrackerXRecord"
' Connect to the dictionary we store the XRecord in
On Error GoTo CREATE
Set TrackingDictionary = ThisDrawing.Dictionaries(TAG_DICTIONARY_NAME)
Set TrackingXRecord = TrackingDictionary.GetObject(TAG_XRECORD_NAME)
On Error GoTo 0
' Get current XRecordData
TrackingXRecord.GetXRecordData XRecordDataType, XRecordData
' If we don't have an array already then create one
If VarType(XRecordDataType) And vbArray = vbArray Then
ArraySize = UBound(XRecordDataType) + 1 ' Get the size of the data elements returned
ArraySize = ArraySize + 1 ' Increase to hold new data
ReDim Preserve XRecordDataType(0 To ArraySize)
ReDim Preserve XRecordData(0 To ArraySize)
Else
ArraySize = 0
ReDim XRecordDataType(0 To ArraySize) As Integer
ReDim XRecordData(0 To ArraySize) As Variant
End If
' Find the current value of TranslateIDs
Dim currXlate As Boolean
currXlate = TrackingXRecord.TranslateIDs
MsgBox "The current setting of the TranslateIDs is " & currXlate
' Toggle the setting
TrackingXRecord.TranslateIDs = Not currXlate
MsgBox "The new setting for the TranslateIDs is " & TrackingXRecord.TranslateIDs
' Reset the value
TrackingXRecord.TranslateIDs = currXlate
MsgBox "TranslateIDs has been reset to " & TrackingXRecord.TranslateIDs
Exit Sub
CREATE:
' Create the entities that hold our XRecordData
If TrackingDictionary Is Nothing Then ' Make sure we have our tracking object
Set TrackingDictionary = ThisDrawing.Dictionaries.Add(TAG_DICTIONARY_NAME)
Set TrackingXRecord = TrackingDictionary.AddXRecord(TAG_XRECORD_NAME)
End If
Resume
可视化 LISP: (vl-load-com)
(defun c:Example_TranslateIDs()
;; This example creates a new XRecord if one doesn't exist,
;; and toggles the setting for TranslateIDs
;; Unique identifiers to distinguish our XRecordData from other XRecordData
(setq TYPE_STRING 1
TAG_DICTIONARY_NAME "ObjectTrackerDictionary"
TAG_XRECORD_NAME "ObjectTrackerXRecord")
;; Connect to the dictionary we store the XRecord in
(setq TrackingDictionary (vl-catch-all-apply 'vla-Item (list dictionaries TAG_DICTIONARY_NAME)))
;; (= (vl-catch-all-error-message TrackingDictionary) "Automation Error. Key not found")
(if (= (type TrackingDictionary) 'VLA-OBJECT)
(setq TrackingXRecord (vla-GetObject TrackingDictionary TAG_XRECORD_NAME))
(progn
;; Create the objects that hold this XRecordData
(setq TrackingDictionary (vla-Add dictionaries TAG_DICTIONARY_NAME))
(setq TrackingXRecord (vla-AddXRecord TrackingDictionary TAG_XRECORD_NAME))
;; Get current XRecordData
(vla-GetXRecordData TrackingXRecord 'temp-XRecordDataType 'temp-XRecordData)
;; If we don't have an array already then create one
(setq ArraySize 0)
(if (/= temp-XRecordDataType nil)
(progn
(setq ArraySize (vlax-safearray-get-u-bound temp-XRecordDataType 1))
(setq XRecordDataType (vlax-make-safearray vlax-vbInteger (cons 0 (1+ ArraySize))))
(setq XRecordData (vlax-make-safearray vlax-vbVariant (cons 0 (1+ ArraySize))))
(setq iCount 0)
(while (>= ArraySize iCount)
;; Get information for this element
(setq DataType (vlax-safearray-get-element temp-XRecordDataType iCount))
(setq Data (vlax-variant-value (vlax-safearray-get-element temp-XRecordData iCount)))
(vlax-safearray-put-element XRecordDataType iCount DataType)
(vlax-safearray-put-element XRecordData iCount Data)
(setq iCount (1+ iCount))
(progn
(setq XRecordDataType (vlax-make-safearray vlax-vbInteger '(0 . 0)))
(setq XRecordData (vlax-make-safearray vlax-vbVariant '(0 . 0)))
;; Find the current value of TranslateIDs
(setq currXlate (vla-get-TranslateIDs TrackingXRecord))
(alert (strcat "The current setting of the TranslateIDs is " (if (= currXlate :vlax-true) "True" "False")))
;; Toggle the setting
(vla-put-TranslateIDs TrackingXRecord (if (= currXlate :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The new setting for the TranslateIDs is " (if (= (vla-get-TranslateIDs TrackingXRecord) :vlax-true) "True" "False")))
;; Reset the value
(vla-put-TranslateIDs TrackingXRecord currXlate)
(alert (strcat "TranslateIDs has been reset to " (if (= (vla-get-TranslateIDs TrackingXRecord) :vlax-true) "True" "False")))
GMT+8, 2026-10-27 21:21
