ToolPalettePath 属性 (ActiveX)
设置工具选项板路径。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 工具选项板路径。 言论没有其他评论。 例子VBA: Sub Example_ToolPalettePath()
'This example changes the tool palette path
'and then sets it to its original string
Dim pref As AutoCAD.AcadPreferencesFiles
Set pref = AcadApplication.Preferences.Files
Dim defToolPalettePath As String
Dim changedToolPalettePath As String
defToolPalettePath = pref.ToolPalettePath
MsgBox "The current tool palette path is " & defToolPalettePath
pref.ToolPalettePath = "c:\winnt;c:\temp"
changedToolPalettePath = pref.ToolPalettePath
MsgBox "The changed tool palette path is " & changedToolPalettePath
pref.ToolPalettePath = defToolPalettePath
可视化 LISP: (vl-load-com)
(defun c:Example_ToolPalettePath()
;; This example changes the tool palette path
;; and then sets it to its original string
(setq pref (vla-get-Files (vla-get-Preferences acadObj)))
(setq defToolPalettePath (vla-get-ToolPalettePath pref))
(alert (strcat "The current tool palette path is " defToolPalettePath))
(vla-put-ToolPalettePath pref "c:\\winnt;c:\\temp")
(alert (strcat "The changed tool palette path is " (vla-get-ToolPalettePath pref)))
(vla-put-ToolPalettePath pref defToolPalettePath)
GMT+8, 2026-10-27 14:13
