ToleranceUpperLimit 属性 (ActiveX)
指定尺寸文本的最大公差限制。 支持的平台:仅限 Windows 签名VBA: object.ToleranceUpperLimit 属性值只读:不 类型:双 公差下限。 言论此属性的初始值为 0.0000。 仅当该属性设置为 、 或 时,此属性才可用。ToleranceDisplayacTolSymmetricalacTolDeviationacTolLimits 注意:此属性将覆盖给定维度的 DIMTP 系统变量的值。
例子VBA: Sub Example_ToleranceLowerLimit()
' sets the tolerance limits using the ToleranceLowerLimit and
' ToleranceUpperLimit properties
Dim dimObj As AcadDimAligned
Dim newText As AcadTextStyle
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Turn on tolerance display
dimObj.ToleranceDisplay = acTolSymmetrical
' Read and display the tolerance limits for the dimension
MsgBox "The tolerance lower limit is set to: " & dimObj.ToleranceLowerLimit & vbCrLf & _
"The tolerance upper limit is set to: " & dimObj.ToleranceUpperLimit
' Adjust the tolerance limits for this dimension
dimObj.ToleranceLowerLimit = 0.0001
dimObj.ToleranceUpperLimit = 0.005
MsgBox "The tolerance lower limit is now set to: " & dimObj.ToleranceLowerLimit & vbCrLf & _
"The tolerance upper limit is now set to: " & dimObj.ToleranceUpperLimit
可视化 LISP: (vl-load-com)
(defun c:Example_ToleranceLowerLimit()
;; sets the tolerance limits using the ToleranceLowerLimit and
;; ToleranceUpperLimit properties
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
;; Turn on tolerance display
(vla-put-ToleranceDisplay dimObj acTolSymmetrical)
(vla-ZoomAll acadObj)
;; Read and display the tolerance limits for the dimension
(alert (strcat "The tolerance lower limit is set to: " (rtos (vla-get-ToleranceLowerLimit dimObj) 2)
"\nThe tolerance upper limit is set to: " (rtos (vla-get-ToleranceUpperLimit dimObj) 2)))
;; Adjust the tolerance limits for this dimension
(vla-put-ToleranceLowerLimit dimObj 0.0001)
(vla-put-ToleranceUpperLimit dimObj 0.005)
(alert (strcat "The tolerance lower limit is now set to: " (rtos (vla-get-ToleranceLowerLimit dimObj) 2)
"\nThe tolerance upper limit is now set to: " (rtos (vla-get-ToleranceUpperLimit dimObj) 2)))
GMT+8, 2026-10-27 16:04
