ToleranceSuppressLeadingZeros 属性 (ActiveX)
指定隐含公差值中的前导零点。 支持的平台:仅限 Windows 签名VBA: object.ToleranceSuppressLeadingZeros 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此值将覆盖 DIMTZIN 系统变量的值。
例子VBA: Sub Example_ToleranceSuppressLeadingZeros()
' uses ToleranceSuppressLeadingZeros to toggle the display of leading zeros
' in the dimension tolerance display
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 5.01: point2(1) = 5: point2(2) = 0
' Enable and setup tolerance display
dimObj.ToleranceDisplay = acTolSymmetrical
dimObj.ToleranceLowerLimit = -0.0001: dimObj.ToleranceUpperLimit = 0.005
Toggle:
Select Case MsgBox("Press OK to toggle the display of leading zeros in the dimension tolerance", vbOKCancel)
Case vbOK
' Toggle the display of leading zeros for the dimension tolerance value
dimObj.ToleranceSuppressLeadingZeros = Not (dimObj.ToleranceSuppressLeadingZeros)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_ToleranceSuppressLeadingZeros()
;; uses ToleranceSuppressLeadingZeros to toggle the display of leading zeros
;; in the dimension tolerance display
;; Define the dimension
point2 (vlax-3d-point 5.01 5 0)
;; Enable and setup tolerance display
(vla-put-ToleranceDisplay dimObj acTolSymmetrical)
(vla-put-ToleranceLowerLimit dimObj -0.0001)
(vla-put-ToleranceUpperLimit dimObj 0.005)
(vla-ZoomAll acadObj)
;; Toggle the display of leading zeros for the dimension tolerance value
(vla-put-ToleranceSuppressLeadingZeros dimObj (if (= (vla-get-ToleranceSuppressLeadingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "Suppression of leading zeros toggled.")
;; Toggle the display of leading zeros for the dimension tolerance value back to previous state
(alert "Suppression of leading zeros toggled back.")
GMT+8, 2026-10-27 19:17
