ToleranceJustification 属性 (ActiveX)
指定公差值相对于标称尺寸文本的垂直对齐方式。 支持的平台:仅限 Windows 签名VBA: object.ToleranceJustification 属性值只读:不 类型:枚举acDimToleranceJustify
言论此属性的初始值为 。acTolMiddle 仅当该属性设置为除 以外的任何值时,此属性才可用。ToleranceDisplayacTolNone 注意:此属性将覆盖给定维度的 DIMTOLJ 系统变量的值。
例子VBA: Sub Example_ToleranceJustification()
' sets the tolerance justification for the dimension to
' a couple of common values
' * Note the vertical position of the tolerance text
Dim dimObj As AcadDimAligned
Dim newText As AcadTextStyle
Dim CurrentDisplay As String
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Turn on tolerance display and increase the dimension text height,
' so the alignment of the tolerance is visible
dimObj.ToleranceDisplay = acTolSymmetrical
dimObj.textHeight = 1
dimObj.ToleranceHeightScale = 0.25
' Read and display the current tolerance justification for this dimension
Select Case dimObj.ToleranceJustification
Case acTolBottom: CurrentDisplay = "Bottom"
Case acTolTop: CurrentDisplay = "Top"
Case acTolMiddle: CurrentDisplay = "Middle"
End Select
MsgBox "The tolerance justification is currently: " & CurrentDisplay
' Set the tolerance justification for this dimension
dimObj.ToleranceJustification = acTolBottom
' Display the current tolerance justification for this dimension
MsgBox "The tolerance display is now set to: Bottom"
可视化 LISP: (vl-load-com)
(defun c:Example_ToleranceJustification()
;; sets the tolerance justification for the dimension to
;; a couple of common values
;; * Note the vertical position of the tolerance text
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
;; Turn on tolerance display and increase the dimension text height,
;; so the alignment of the tolerance is visible
(vla-put-ToleranceDisplay dimObj acTolSymmetrical)
(vla-put-TextHeight dimObj 1)
(vla-put-ToleranceHeightScale dimObj 0.25)
(vla-ZoomAll acadObj)
;; Read and display the current tolerance justification for this dimension
(setq currentDisplay (cond
((= (vla-get-ToleranceJustification dimObj) acTolBottom) "Bottom")
((= (vla-get-ToleranceJustification dimObj) acTolTop) "Top")
((= (vla-get-ToleranceJustification dimObj) acTolMiddle) "Middle")
(alert (strcat "The tolerance justification is currently: " currentDisplay))
;; Set the tolerance justification for this dimension
(vla-put-ToleranceJustification dimObj acTolBottom)
;; Display the current tolerance justification for this dimension
(alert "The tolerance display is now set to: Bottom")
GMT+8, 2026-10-27 21:33
