ToleranceDisplay 属性 (ActiveX)
指定公差是否与尺寸文本一起显示。 支持的平台:仅限 Windows 签名VBA: object.ToleranceDisplay 属性值只读:不 类型:枚举acDimToleranceMethod
言论此属性的初始值为 。acTolNone 注意:此属性将覆盖给定维度的 DIMTOL 系统变量的值。
例子VBA: Sub Example_ToleranceDisplay()
' turns on the tolerance display for the new dimension
Dim dimObj As AcadDimAligned
Dim newText As AcadTextStyle
Dim CurrentDisplay As String
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Read and display the current tolerance display for this dimension
CurrentDisplay = IIf(dimObj.ToleranceDisplay = acTolNone, "Hidden", "Visible")
MsgBox "The tolerance display is currently: " & CurrentDisplay
' Toggle the tolerance display for this dimension
If dimObj.ToleranceDisplay = acTolNone Then
dimObj.ToleranceDisplay = acTolSymmetrical
CurrentDisplay = "Symmetrical"
Else
CurrentDisplay = "None"
End If
' Display the current tolerance display for this dimension
MsgBox "The tolerance display is now set to: " & CurrentDisplay
可视化 LISP: (vl-load-com)
(defun c:Example_ToleranceDisplay()
;; turns on the tolerance display for the new dimension
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
(vla-ZoomAll acadObj)
;; Read and display the current tolerance display for this dimension
(setq currentDisplay (if (= (vla-get-ToleranceDisplay dimObj) acTolNone) "Hidden" "Visible"))
(alert (strcat "The tolerance display is currently: " currentDisplay))
;; Toggle the tolerance display for this dimension
(progn
(vla-put-ToleranceDisplay dimObj acTolSymmetrical)
(setq currentDisplay "Symmetrical")
(progn
(vla-put-ToleranceDisplay dimObj acTolNone)
(setq currentDisplay "None")
;; Display the current tolerance display for this dimension
(alert (strcat "The tolerance display is now set to: " currentDisplay))
GMT+8, 2026-10-28 03:05
