TimeServer 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 864| 评论: 0|原作者: admin|来自: AutoCAD
指定用于数字签名的时间服务器的名称。
object.TimeServer
类型:SecurityParams
此属性应用于的对象。
只读:不
类型:字符串
用于数字签名的时间服务器的名称。
如果未设置此属性,则本地计算机的时间将用作数字签名的时间戳。
Sub Example_TimeServer()
    ' This example attaches a digital signature and accompanying data to a file,
    ' and saves the file.
    Dim sp As AcadSecurityParams
    Set sp = GetInterfaceObject("AutoCAD.SecurityParams." + Left(AcadApplication.Version, 2))
    ' Attach a digital signature and timestamp it
    sp.Action = AcadSecurityParamsType.ACADSECURITYPARAMS_SIGN_DATA _
                + AcadSecurityParamsType.ACADSECURITYPARAMS_ADD_TIMESTAMP
    ' Certificate details follow
    sp.Subject = "Thawte Freemail Member"
    sp.Issuer = "Personal Freemail RSA 2000.8.30"
    sp.SerialNumber = "073848"
    sp.Comment = "This is now signed"
    sp.TimeServer = "NIST(time.nist.gov)"
    ' To set the TimeServer property, use a description followed by the Internet address in parentheses
    ThisDrawing.SaveAs "C:\MyDrawing.dwg", , sp
(defun c:Example_TimeServer()
    ;; This example attaches a digital signature and accompanying data to a file,
    ;; and saves the file.
    (setq sp (vlax-create-object (strcat "AutoCAD.SecurityParams." (substr (getvar "ACADVER") 1 2))))
    (vla-put-Visible acadObj :vlax-true)
    ;; Attach a digital signature and timestamp it
    (vla-put-Action sp (+ ACADSECURITYPARAMS_SIGN_DATA ACADSECURITYPARAMS_ADD_TIMESTAMP))
    ;; Certificate details follow
    (vla-put-Subject sp "Thawte Freemail Member")
    (vla-put-Issuer sp "Personal Freemail RSA 2000.8.30")
    (vla-put-SerialNumber sp "073848")
    (vla-put-Comment sp "This is now signed")
    (vla-put-TimeServer sp "NIST(time.nist.gov)")
    ;; To set the TimeServer property, use a description followed by the Internet address in parentheses
    (vla-SaveAs doc "C:\\MyDrawing.dwg" acNative sp)
    (vlax-release-object sp)
GMT+8, 2026-10-28 13:23
