Thickness 属性 (ActiveX)
指定 2D AutoCAD 对象在其高程上方或下方拉伸的距离。 支持的平台:仅限 Windows 属性值只读:不 类型:双 默认值为 0.0。 言论更改对象的厚度会更改其 Z 方向厚度。 ![]() 更改 3D 折线、尺寸或浮动视口的粗细不起作用。 例子VBA: Sub Example_Thickness()
' This example creates a circle in model space
' and changes the thickness of the circle.
Dim circleObj As AcadCircle
Dim radius As Double
' Define the circle
centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
radius = 5#
' Create the Circle object in model space
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
ZoomAll
' Find the current thickness of the circle
Dim currThickness As Double
currThickness = circleObj.Thickness
MsgBox "The thickness of the circle is " & circleObj.Thickness, vbInformation, "Thickness Example"
' Change the thickness of the circle
circleObj.Thickness = currThickness + 3
circleObj.Update
' Change the direction of the viewport so that you can
' view the change made to the thickness. Once you change
' the direction, you must reset the active viewport.
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
MsgBox "The thickness of the circle is now " & circleObj.Thickness, vbInformation, "Thickness Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Thickness()
;; This example creates a circle in model space
;; and changes the thickness of the circle.
;; Define the circle
(setq centerPoint (vlax-3d-point 0 0 0)
radius 5)
;; Create the Circle object in model space
(setq circleObj (vla-AddCircle modelSpace centerPoint radius))
(vla-ZoomAll acadObj)
;; Find the current thickness of the circle
(setq currThickness (vla-get-Thickness circleObj))
(alert (strcat "The thickness of the circle is " (rtos currThickness 2)))
;; Change the thickness of the circle
(vla-put-Thickness circleObj (+ currThickness 3))
(vla-Update circleObj)
;; Change the direction of the viewport so that you can
;; view the change made to the thickness. Once you change
;; the direction, you must reset the active viewport.
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(alert (strcat "The thickness of the circle is now " (rtos (vla-get-Thickness circleObj) 2)))
GMT+8, 2026-10-27 22:42
