TextWinTextColor 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 881| 评论: 0|原作者: admin|来自: AutoCAD
指定文本窗口的文本颜色。
object.TextWinTextColor
类型:首选项显示
此属性应用于的对象。
只读:是/否
类型:OLE_COLOR(常量)
  • vbBlack
  • vbRed
  • vbYellow
  • vbGreen
  • vbCyan
  • vbBlue
  • vbMagenta
  • vbWhite
此属性的默认颜色是 Windows 标准窗口文本颜色。
Sub Example_TextWinTextColor()
    ' TextWinTextColor. It then changes the value, and finally
    Dim currTextWinTextColor As Long
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current TextWinTextColor value
    currTextWinTextColor = preferences.Display.TextWinTextColor
    MsgBox "The current value for TextWinTextColor is " _
           & preferences.Display.TextWinTextColor, vbInformation, "TextWinTextColor Example"
    ' Change the value for TextWinTextColor
    preferences.Display.TextWinTextColor = vbGreen
    MsgBox "The new value for TextWinTextColor is " _
    ' Reset TextWinTextColor to its original value
    preferences.Display.TextWinTextColor = currTextWinTextColor
    MsgBox "The TextWinTextColor value is reset to " _
(defun c:Example_TextWinTextColor()
    ;; TextWinTextColor. It then changes the value, and finally
    ;; Get the Display preferences object
    (setq ACADPref (vla-get-Display preferences))
    ;; Retrieve the current TextWinTextColor value
    (setq currTextWinTextColor (vlax-variant-change-type (vla-get-TextWinTextColor ACADPref) vlax-vbLong))
    (alert (strcat "The current value for TextWinTextColor is " (itoa (vlax-variant-value currTextWinTextColor))))
    ;; Change the value for TextWinTextColor
    (vla-put-TextWinTextColor ACADPref (vlax-make-variant acGreen 19))
    (setq newValue (vlax-variant-change-type (vla-get-TextWinTextColor ACADPref) vlax-vbLong))
    (alert (strcat "The new value for TextWinTextColor is " (itoa (vlax-variant-value newValue))))
    ;; Reset TextWinTextColor to its original value
    (vla-put-TextWinTextColor ACADPref (vlax-variant-change-type currTextWinTextColor 19))
    (alert (strcat "The TextWinTextColor value is reset to " (itoa (vlax-variant-value currTextWinTextColor))))
GMT+8, 2026-10-27 14:13
