TextureMapPath 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 801| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoCAD 在其中搜索渲染纹理贴图的目录。
object.TextureMapPath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
用于渲染纹理贴图的目录的位置。
可以使用分号 (;) to paths 输入多个路径。
Sub Example_TextureMapPath()
    ' TextureMapPath. It then changes the value, and finally
    Dim currTextureMapPath As String
    Dim newTextureMapPath As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current TextureMapPath value
    currTextureMapPath = preferences.Files.TextureMapPath
    MsgBox "The current value for TextureMapPath is " & currTextureMapPath, vbInformation, "TextureMapPath Example"
    ' Change the value for TextureMapPath
    newTextureMapPath = "TestTextureMapPath"
    preferences.Files.TextureMapPath = newTextureMapPath
    MsgBox "The new value for TextureMapPath is " & newTextureMapPath, vbInformation, "TextureMapPath Example"
    ' Reset TextureMapPath to its original value
    preferences.Files.TextureMapPath = currTextureMapPath
    MsgBox "The TextureMapPath value is reset to " & currTextureMapPath, vbInformation, "TextureMapPath Example"
(defun c:Example_TextureMapPath()
    ;; TextureMapPath. It then changes the value, and finally
    ;; Retrieve the current TextureMapPath value
    (setq currTextureMapPath (vla-get-TextureMapPath (vla-get-Files preferences)))
    (alert (strcat "The current value for TextureMapPath is " currTextureMapPath))
    ;; Change the value for TextureMapPath
    (setq newTextureMapPath "TestTextureMapPath")
    (vla-put-TextureMapPath (vla-get-Files preferences) newTextureMapPath)
    (alert (strcat "The new value for TextureMapPath is " newTextureMapPath))
    ;; Reset TextureMapPath to its original value
    (vla-put-TextureMapPath (vla-get-Files preferences) currTextureMapPath)
    (alert (strcat "The TextureMapPath value is reset to " currTextureMapPath))
GMT+8, 2026-10-26 13:00
