TextStyles 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 767| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 TextStyles 集合。
object.TextStyles
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型:TextStyles
文档的集合。TextStyles
Sub Example_TextStyles()
    ' This example finds the current Textstyles collection and
    ' adds a new Text style to that collection.
    Dim TextColl As AcadTextStyles
    Set TextColl = ThisDrawing.TextStyles
    ' Create a Text style named "TEST" in the current drawing
    Dim textStyle As AcadTextStyle
    Set textStyle = TextColl.Add("TEST")
    MsgBox "A new Text style called " & textStyle.name & " has been added to the Textstyles collection.", vbInformation, "Textstyles Example"
(defun c:Example_TextStyles()
    ;; This example finds the current Textstyles collection and
    ;; adds a new Text style to that collection.
    (setq TextColl (vla-get-TextStyles doc))
    ;; Create a Text style named "TEST" in the current drawing
    (setq textStyle (vla-Add TextColl "TEST"))
    (alert (strcat "A new Text style called " (vla-get-Name textStyle) " has been added to the Textstyles collection."))
GMT+8, 2026-10-28 07:34
