TextStyle 属性 (ActiveX)
指定尺寸或公差文本的文本样式。 支持的平台:仅限 Windows 签名VBA: object.TextStyle 属性值只读:不 类型:字符串 维度值的样式。 言论此属性的初始值为 STANDARD。 注意:此属性将覆盖给定维度的 DIMTXSTY 系统变量的值。
例子VBA: Sub Example_TextStyle()
' creates a new system text style. The new text style is then assigned to
' the new dimension
Dim dimObj As AcadDimAligned
Dim newText As AcadTextStyle
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Create new text style
Set newText = ThisDrawing.TextStyles.Add("MYSTYLE")
newText.height = 0.5 ' Just set the height of the new style so we can differentiate
' Read and display the current text style for this dimension
MsgBox "The text style is currently set to: " & dimObj.textStyle
' Change the text style to use the new style we created
dimObj.textStyle = "MYSTYLE"
MsgBox "The text style is now set to: " & dimObj.textStyle
可视化 LISP: (vl-load-com)
(defun c:Example_TextStyle()
;; creates a new system text style. The new text style is then assigned to
;; the new dimension
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
;; Create new text style
(setq newText (vla-Add (vla-get-TextStyles doc) "MYSTYLE"))
(vla-put-Height newText 0.5) ;; Just set the height of the new style so we can differentiate
(vla-ZoomAll acadObj)
;; Read and display the current text style for this dimension
(alert (strcat "The text style is currently set to: " (vla-get-TextStyle dimObj)))
;; Change the text style to use the new style we created
(vla-put-TextStyle dimObj "MYSTYLE")
(alert (strcat "The text style is now set to: " (vla-get-TextStyle dimObj)))
GMT+8, 2026-11-15 14:57
