TextPrecision 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 934| 评论: 0|原作者: admin|来自: AutoCAD
指定角度标注文本的精度。
object.TextPrecision
类型:Dim3PointAngularDimAngular
此属性应用于的对象。
只读:
类型:枚举acDimPrecision
  • acDimPrecisionZero: 0.
  • acDimPrecisionOne: 0.0
  • acDimPrecisionTwo: 0.00
  • acDimPrecisionThree: 0.000
  • acDimPrecisionFour: 0.0000
  • acDimPrecisionFive: 0.00000
  • acDimPrecisionSix: 0.000000
  • acDimPrecisionSeven: 0.0000000
  • acDimPrecisionEight: 0.00000000
注意:此属性将覆盖给定尺寸的 DIMADEC 系统变量的值。
Sub Example_TextPrecision()
    ' This example creates a Dim3PointAngular object in model space and
    ' uses the TextPrecision property to set the precision of
    ' the dimension text to 4 decimal places
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current dimension text precision
    MsgBox "The dimension text precision is currently set to: " & DimPointAngularObj.TextPrecision
    ' Increase the distance of the dimension gap
    DimPointAngularObj.TextPrecision = acDimPrecisionFour
    MsgBox "The dimension text precision is now set to: " & DimPointAngularObj.TextPrecision
(defun c:Example_TextPrecision()
    ;; This example creates a Dim3PointAngular object in model space and
    ;; uses the TextPrecision property to set the precision of
    ;; the dimension text to 4 decimal places
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq dimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current dimension text precision
    (alert (strcat "The dimension text precision is currently set to: " (itoa (vla-get-TextPrecision dimPointAngularObj))))
    ;; Increase the distance of the dimension gap
    (vla-put-TextPrecision dimPointAngularObj acDimPrecisionFour)
    (alert (strcat "The dimension text precision is now set to: " (rtos (vla-get-TextPrecision dimPointAngularObj) 2)))
GMT+8, 2026-9-13 02:39
