TextOverride 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 803| 评论: 0|原作者: admin|来自: AutoCAD
指定维度的文本字符串。
object.TextOverride
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:字符串
最大长度为 256 个字符。
用户字符串将替换计算出的维度值。您可以通过将文本设置为字符串 (“”) 来恢复计算出的维度值。您可以使用一组闭合的括号 (<>) 来表示主维度值,从而在主维度值后附加文本或为其添加前缀。显示字符串时,主维度值将替换括号。例如,= “<> mm” 将导致显示一个字符串 “3.5 mm”,其中尺寸值为 3.5。还可以使用方括号 ( [] ) 包含二级维度值。NULLTextString
Sub Example_TextOverride()
    ' This example creates an aligned dimension and then changes the
    ' TextOverride property for that dimension.
    Dim dimObj As AcadDimAligned
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    ' Define the dimension
    point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
    point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
    location(0) = 7.5: location(1) = 5#: location(2) = 0#
    ZoomAll
    MsgBox "The initial text string for the dimension contains only the dimension value.", vbInformation, "TextOverride Example"
    ' Change the text string for the dimension
    dimObj.TextOverride = "The value is <>"
    dimObj.Update
    MsgBox "The text string for the dimension has been replaced. However, the dimension value is still represented.", vbInformation, "TextOverride Example"
    ' Reset the text string for the dimension
    dimObj.TextOverride = ""
    dimObj.Update
    MsgBox "The text string for the dimension is reset.", vbInformation, "TextOverride Example"
(defun c:Example_TextOverride()
    ;; This example creates an aligned dimension and then changes the
    ;; TextOverride property for that dimension.
    ;; Define the dimension
    (setq point1 (vlax-3d-point 5 3 0)
          point2 (vlax-3d-point 10 3 0)
          location (vlax-3d-point 7.5 5 0))
    (vla-ZoomAll acadObj)
    (alert "The initial text string for the dimension contains only the dimension value.")
    ;; Change the text string for the dimension
    (vla-put-TextOverride dimObj "The value is <>")
    (vla-Update dimObj)
    (alert "The text string for the dimension has been replaced. However, the dimension value is still represented.")
    ;; Reset the text string for the dimension
    (vla-put-TextOverride dimObj "")
    (vla-Update dimObj)
    (alert "The text string for the dimension is reset.")
GMT+8, 2026-10-27 22:03
