TextGap 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 813| 评论: 0|原作者: admin|来自: AutoCAD
指定在分割尺寸线以容纳尺寸文本时尺寸文本与尺寸线之间的距离。
object.TextGap
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated、Leader
此属性应用于的对象。
只读:不
类型:双
指定间隙距离的实数。
此属性还设置对象上的批注和挂钩线之间的间隙。Leader
负值创建基本尺寸标注(文本周围带有框的尺寸文本)。
注意:此属性将覆盖给定维度的 DIMGAP 系统变量的值。
Sub Example_TextGap()
   ' uses the TextGap property to increase the distance between the
   ' dimension line and the dimension text
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Read and display current dimension gap
    MsgBox "The dimension gap for this object is currently set to: " & dimObj.TextGap
    ' Increase the distance of the dimension gap
    dimObj.TextGap = 0.5
    MsgBox "The dimension gap for this object is now set to: " & dimObj.TextGap
(defun c:Example_TextGap()
    ;; uses the TextGap property to increase the distance between the
    ;; dimension line and the dimension text
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display current dimension gap
    (alert (strcat "The dimension gap for this object is currently set to: " (rtos (vla-get-TextGap dimObj) 2)))
    ;; Increase the distance of the dimension gap
    (vla-put-TextGap dimObj 0.5)
    (alert (strcat "The dimension gap for this object is now set to: " (rtos (vla-get-TextGap dimObj) 2)))
GMT+8, 2026-10-26 12:22
