TextFontStyle 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 923| 评论: 0|原作者: admin|来自: AutoCAD
指定新文本的字体样式。
object.TextFontStyle
类型:首选项显示
此属性应用于的对象。
只读:不
类型:枚举acTextFontStyle
  • acFontRegular
  • acFontItalic
  • acFontBold
  • acFontBoldItalic
此属性的初始值为 。acFontRegular
Sub Example_TextFontStyle()
    ' TextFontStyle. It then changes the value, and finally
    Dim currTextFontStyle As Integer
    Dim constant As String
    Dim newConstant As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current TextFontStyle value
    currTextFontStyle = preferences.Display.TextFontStyle
    constant = Choose(currTextFontStyle + 1, "acFontRegular", "acFontItalic", "acFontBold", "acFontBoldItalic")
    MsgBox "The current value for TextFontStyle is " & constant, vbInformation, "TextFontStyle Example"
    ' Change the value for TextFontStyle
    newConstant = "acFontBoldItalic"
    preferences.Display.TextFontStyle = acFontBoldItalic
    MsgBox "The new value for TextFontStyle is " & newConstant, vbInformation, "TextFontStyle Example"
    ' Reset TextFontStyle to its original value
    preferences.Display.TextFontStyle = currTextFontStyle
    MsgBox "The TextFontStyle value is reset to " & constant, vbInformation, "TextFontStyle Example"
(defun c:Example_TextFontStyle()
    ;; TextFontStyle. It then changes the value, and finally
    ;; Retrieve the current TextFontStyle value
    (setq currTextFontStyle (vla-get-TextFontStyle (vla-get-Display preferences)))
    (setq constant (cond
                       ((= currTextFontStyle acFontRegular) "acFontRegular")
                       ((= currTextFontStyle acFontItalic) "acFontItalic")
                       ((= currTextFontStyle acFontBold) "acFontBold")
                       ((= currTextFontStyle acFontBoldItalic) "acFontBoldItalic")
    (alert (strcat "The current value for TextFontStyle is " constant))
    ;; Change the value for TextFontStyle
    (vla-put-TextFontStyle (vla-get-Display preferences) acFontBoldItalic)
    (setq newTextFontStyle (vla-get-TextFontStyle (vla-get-Display preferences)))
    (setq newConstant (cond
                       ((= newTextFontStyle acFontRegular) "acFontRegular")
                       ((= newTextFontStyle acFontItalic) "acFontItalic")
                       ((= newTextFontStyle acFontBold) "acFontBold")
                       ((= newTextFontStyle acFontBoldItalic) "acFontBoldItalic")
    (alert (strcat "The new value for TextFontStyle is " newConstant))
    ;; Reset TextFontStyle to its original value
    (vla-put-TextFontStyle (vla-get-Display preferences) currTextFontStyle)
    (alert (strcat "The TextFontStyle value is reset to " constant))
GMT+8, 2026-10-27 21:14
