TextColor 属性 (ActiveX)
指定尺寸和公差对象的文本颜色。 支持的平台:仅限 Windows 签名VBA: object.TextColor 属性值只读:不 类型:枚举acColor 使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:
言论可以将颜色设置为从 0 到 256 的数字索引值并读取。为标准七种颜色以及 BYBLOCK 和 BYLAYER 名称提供了常量。 如果使用 ,AutoCAD 将以默认颜色(白色或黑色,具体取决于您的配置)绘制新对象,直到它们被分组到块中。在图形中插入块时,块中的对象将继承颜色属性的当前设置。acByBlock 如果使用 ,则新对象将采用绘制它们的图层的颜色。acByLayer 注意:此属性将覆盖给定尺寸或公差对象的 DIMCLRT 系统变量的值。
例子VBA: Sub Example_TextColor()
' uses the TextColor property to toggle the dimension text color to red
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 7: point2(1) = 5: point2(2) = 0
' Read and display current dimension text color
MsgBox "The dimension text color for this object is currently set to: " & dimObj.TextColor
' Change the dimension text color
dimObj.TextColor = acRed
MsgBox "The dimension text color for this object is now set to: " & dimObj.TextColor & " (Red)"
可视化 LISP: (vl-load-com)
(defun c:Example_TextColor()
;; uses the TextColor property to toggle the dimension text color to red
;; Define the dimension
point2 (vlax-3d-point 7 5 0)
(vla-ZoomAll acadObj)
;; Read and display current dimension text color
(alert (strcat "The dimension text color for this object is currently set to: " (itoa (vla-get-TextColor dimObj))))
;; Change the dimension text color
(vla-put-TextColor dimObj acRed)
(alert (strcat "The dimension text color for this object is now set to: " (itoa (vla-get-TextColor dimObj)) " (Red)"))
GMT+8, 2026-10-26 13:52
