TempFilePath 属性 (ActiveX)
指定 AutoCAD 用于存储临时文件的目录。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 用于临时文件的目录的驱动器和路径。 言论没有其他评论。 例子VBA: Sub Example_TempFilePath()
' TempFilePath. It then changes the value, and finally
Dim currTempFilePath As String
Dim newTempFilePath As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current TempFilePath value
currTempFilePath = preferences.Files.TempFilePath
MsgBox "The current value for TempFilePath is " & currTempFilePath, vbInformation, "TempFilePath Example"
' Change the value for TempFilePath
newTempFilePath = "C:\AutoCAD\"
preferences.Files.TempFilePath = newTempFilePath
MsgBox "The new value for TempFilePath is " & newTempFilePath, vbInformation, "TempFilePath Example"
' Reset TempFilePath to its original value
preferences.Files.TempFilePath = currTempFilePath
MsgBox "The TempFilePath value is reset to " & currTempFilePath, vbInformation, "TempFilePath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TempFilePath()
;; TempFilePath. It then changes the value, and finally
;; Retrieve the current TempFilePath value
(setq currTempFilePath (vla-get-TempFilePath (vla-get-Files preferences)))
(alert (strcat "The current value for TempFilePath is " currTempFilePath))
;; Change the value for TempFilePath
(setq newTempFilePath "C:\\AutoCAD\\")
(vla-put-TempFilePath (vla-get-Files preferences) newTempFilePath)
(alert (strcat "The new value for TempFilePath is " newTempFilePath))
;; Reset TempFilePath to its original value
(vla-put-TempFilePath (vla-get-Files preferences) currTempFilePath)
(alert (strcat "The TempFilePath value is reset to " currTempFilePath))
GMT+8, 2026-10-26 15:13
