TempFileExtension 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 668| 评论: 0|原作者: admin|来自: AutoCAD
指定临时文件的扩展名。
object.TempFileExtension
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:字符串
此字符串必须介于 1 到 3 个字符之间(含 1 到 3 个字符)。
此属性的默认值为 ac$。
临时文件扩展名是用于临时文件的一到三个字符的扩展名。在多用户环境中,可以通过为每个用户指定不同的名称来避免混淆。
Sub Example_TempFileExtension()
    ' TempFileExtension. It then changes the value, and finally
    Dim currTempFileExtension As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current TempFileExtension value
    currTempFileExtension = preferences.OpenSave.TempFileExtension
    MsgBox "The current value for TempFileExtension is " & preferences.OpenSave.TempFileExtension, vbInformation, "TempFileExtension Example"
    ' Change the value for TempFileExtension
    preferences.OpenSave.TempFileExtension = "@@@"
    MsgBox "The new value for TempFileExtension is " & preferences.OpenSave.TempFileExtension, vbInformation, "TempFileExtension Example"
    ' Reset TempFileExtension to its original value
    preferences.OpenSave.TempFileExtension = currTempFileExtension
    MsgBox "The TempFileExtension value is reset to " & preferences.OpenSave.TempFileExtension, vbInformation, "TempFileExtension Example"
(defun c:Example_TempFileExtension()
    ;; TempFileExtension. It then changes the value, and finally
    ;; Retrieve the current TempFileExtension value
    (setq currTempFileExtension (vla-get-TempFileExtension (vla-get-OpenSave preferences)))
    (alert (strcat "The current value for TempFileExtension is " currTempFileExtension))
    ;; Change the value for TempFileExtension
    (vla-put-TempFileExtension (vla-get-OpenSave preferences) "@@@")
    (alert (strcat "The new value for TempFileExtension is " (vla-get-TempFileExtension (vla-get-OpenSave preferences))))
    ;; Reset TempFileExtension to its original value
    (vla-put-TempFileExtension (vla-get-OpenSave preferences) currTempFileExtension)
    (alert (strcat "The TempFileExtension value is reset to " (vla-get-TempFileExtension (vla-get-OpenSave preferences))))
GMT+8, 2026-10-28 20:26
