TablesReadOnly 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 639| 评论: 0|原作者: admin|来自: AutoCAD
确定是否以只读模式打开数据库表。
object.TablesReadOnly
类型:PreferencesSystem
此属性应用于的对象。
只读:不
类型:布尔
  • True:以只读模式打开数据库表。
  • False:以读写模式打开数据库表。
此属性的初始值为 。False
Sub Example_TablesReadOnly()
    ' This example reads and modifies the preference value that controls
    ' whether to open database tables in read-only mode.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSystem
    ' Get the system preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.System
    originalValue = ACADPref.TablesReadOnly
    MsgBox "The TablesReadOnly preference is set to: " & originalValue
    ' Modify the TablesReadOnly preference by toggling the value
    ACADPref.TablesReadOnly = Not (ACADPref.TablesReadOnly)
    newValue = ACADPref.TablesReadOnly
    MsgBox "The TablesReadOnly preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.TablesReadOnly = originalValue
    MsgBox "The TablesReadOnly preference was reset back to: " & originalValue
(defun c:Example_TablesReadOnly()
    ;; This example reads and modifies the preference value that controls
    ;; whether to open database tables in read-only mode.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-TablesReadOnly (vla-get-System preferences)))
    (alert (strcat "The TablesReadOnly preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the TablesReadOnly preference by toggling the value
    (vla-put-TablesReadOnly (vla-get-System preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The TablesReadOnly preference has been set to: " (if (= (vla-get-TablesReadOnly (vla-get-System preferences)) :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-TablesReadOnly (vla-get-System preferences) originalValue)
    (alert (strcat "The TablesReadOnly preference was reset back to: " (if (= (vla-get-TablesReadOnly (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-29 02:44
