System 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 837| 评论: 0|原作者: admin|来自: AutoCAD
System 属性 (ActiveX)
获取 PreferencesSystem 对象。
object.System
类型:首选项
此属性应用于的对象。
只读:是的
类型:PreferencesSystem
获取对象。PreferencesSystem
该对象保存存储在注册表中的“选项”对话框的“系统”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesSystemDatabasePreferences
Sub Example_System()
    ' This example obtains a reference to the System Preferences object
    ' from the Application Preferences object, and reads one of the System
    ' preferences
    Dim ACADPref As AcadPreferencesSystem
    ' Obtain a reference to the System Preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.System
    MsgBox "You now have access to the properties and methods of the System Preferences object!"
    MsgBox "The System preference BeepOnError is set to: " & ACADPref.BeepOnError
(defun c:Example_System()
    ;; This example obtains a reference to the System Preferences object
    ;; from the Application Preferences object, and reads one of the System
    ;; preferences
    (alert "You now have access to the properties and methods of the System Preferences object!")
    (alert (strcat "The System preference BeepOnError is set to: " (if (= (vla-get-BeepOnError (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-11-15 11:55
