SupportPath 属性 (ActiveX)
指定 AutoCAD 搜索支持文件的目录。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 支持文件所在的目录。指定支持、字体、帮助和奖励文件的驱动器号和路径。 言论使用分号 (;) 分隔多个目录;但是,不要以分号结束字符串。 例子VBA: Sub Example_SupportPath()
' SupportPath. It then changes the value, and finally
Dim currSupportPath As String
Dim newSupportPath As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current SupportPath value
currSupportPath = preferences.Files.SupportPath
MsgBox "The current value for SupportPath is " & currSupportPath, vbInformation, "SupportPath Example"
' Change the value for SupportPath
newSupportPath = "TestSupportPath"
preferences.Files.SupportPath = newSupportPath
MsgBox "The new value for SupportPath is " & newSupportPath, vbInformation, "SupportPath Example"
' Reset SupportPath to its original value
preferences.Files.SupportPath = currSupportPath
MsgBox "The SupportPath value is reset to " & currSupportPath, vbInformation, "SupportPath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SupportPath()
;; SupportPath. It then changes the value, and finally
;; Retrieve the current SupportPath value
(setq currSupportPath (vla-get-SupportPath (vla-get-Files preferences)))
(alert (strcat "The current value for SupportPath is " currSupportPath))
;; Change the value for SupportPath
(setq newSupportPath "TestSupportPath")
(vla-put-SupportPath (vla-get-Files preferences) newSupportPath)
(alert (strcat "The new value for SupportPath is " newSupportPath))
;; Reset SupportPath to its original value
(vla-put-SupportPath (vla-get-Files preferences) currSupportPath)
(alert (strcat "The SupportPath value is reset to " currSupportPath))
GMT+8, 2026-10-28 18:11
