StartParameter 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 996| 评论: 0|原作者: admin|来自: AutoCAD
指定椭圆的起始参数。
object.StartParameter
类型:椭圆
此属性应用于的对象。
只读:不
类型:双
有效范围为 0 到 。2*PI
椭圆的起始和结束参数根据以下公式计算:
P(Theta) = A * cos(Theta) + B * sin(Theta)
其中 和 分别是半长轴和短轴。AB
例如,如果起始角度为 ,则根据上述公式计算相应的起始参数。同样,如果您的端角为 ,则根据上述公式计算相应的端部参数。Theta1P(Theta1)Theta2P(Theta2)
您可以使用角度或参数来创建椭圆。
Sub Example_StartParameter()
    ' This example creates an ellipse and enters the start and
    ' end parameters to create an elliptical arc.
    Dim ellObj As AcadEllipse
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    ' Create an ellipse in model space
    center(0) = 5#: center(1) = 5#: center(2) = 0#
    majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
    radRatio = 0.3
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ' Enter a start parameter of 1.57, and an end parameter of 6.28
    ellObj.StartParameter = 1.57
    ellObj.EndParameter = 6.28
    ZoomAll
    ' Find the start and end parameters for the ellipse
    MsgBox "The ellipse has a start parameter of " & ellObj.StartParameter & " and an end parameter of " & ellObj.EndParameter, vbInformation, "StartParameter Example"
(defun c:Example_StartParameter()
    ;; This example creates an ellipse and enters the start and
    ;; end parameters to create an elliptical arc.
    ;; Create an ellipse in model space
    (setq center (vlax-3d-point 5 5 0)
          majAxis (vlax-3d-point 10 20 0)
          radRatio 0.3)
    (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
    ;; Enter a start parameter of 1.57, and an end parameter of 6.28
    (vla-put-StartParameter ellObj 1.57)
    (vla-put-EndParameter ellObj 6.28)
    (vla-ZoomAll acadObj)
    ;; Find the start and end parameters for the ellipse
    (alert (strcat "The ellipse has a start parameter of " (rtos (vla-get-StartParameter ellObj) 2) " and an end parameter of " (rtos (vla-get-EndParameter ellObj) 2)))
GMT+8, 2026-10-28 04:16
