StandardScale2 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 952| 评论: 0|原作者: admin|来自: AutoCAD
指定视口的标准比例。
object.StandardScale2
类型: PViewport
此属性应用于的对象。
只读:不
类型:长
视口的标准比例值。
Sub Example_StandardScale()
    ' This example will access the active layout for the current drawing
    ' and list the standard scale for that Layout.
    ' It then changes the standard scale for the layout, and finally
    ' resets the scale back to its original value.
    Dim Layout As ACADLayout
    Dim currScale As Integer
    ' Get the activeLayout
    Set Layout = ThisDrawing.ActiveLayout
    ' Find the current standard scale
    currScale = Layout.StandardScale
    MsgBox "The current standard scale is : " & Layout.StandardScale
    ' Change the standard scale to 100:1
    Layout.StandardScale = ac100_1
    MsgBox "The new standard scale is : " & Layout.StandardScale
    ' Reset the original standard scale
    Layout.StandardScale = currScale
(defun c:Example_StandardScale()
    ;; This example will access the active layout for the current drawing
    ;; and list the standard scale for that Layout.
    ;; It then changes the standard scale for the layout, and finally
    ;; resets the scale back to its original value.
    ;; Get the activeLayout
    (setq Layout (vla-get-ActiveLayout doc))
    ;; Find the current standard scale
    (setq currScale (vla-get-StandardScale Layout))
    (alert (strcat "The current standard scale is : " (itoa currScale)))
    ;; Change the standard scale to 100:1
    (vla-put-StandardScale Layout ac100_1)
    (alert (strcat "The new standard scale is : " (itoa (vla-get-StandardScale Layout))))
    ;; Reset the original standard scale
    (vla-put-StandardScale Layout currScale)
GMT+8, 2026-10-31 12:48
