SnapOn 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 627| 评论: 0|原作者: admin|来自: AutoCAD
SnapOn 属性 (ActiveX)
指定捕捉的状态。
object.SnapOn
类型:PViewport视口
此属性应用于的对象。
只读:
类型:布尔
  • True:捕捉已打开。
  • False:捕捉已关闭。
SnapOn使用当前对齐网格分辨率、旋转和样式激活对齐模式。若要更改捕捉栅格分辨率,请使用以下方法。若要更改对齐旋转,请使用属性。SetSnapSpacingSnapRotationAngle
捕捉网格是不可见的。使用该属性可显示单独的可见网格。GridOn
AutoCAD 会忽略透视图中的“捕捉”模式。
注意:此属性的值存储在 SNAPMODE 系统变量中。要更改捕捉样式,请使用 SNAPSTYL 系统变量。
Sub Example_SnapOn()
    ' This example toggles the setting of SnapOn.
    Dim viewportObj As AcadViewport
    ' Set the viewportObj variable to the activeviewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Display the current setting of SnapOn
    MsgBox "Snap mode is: " & IIf(viewportObj.SnapOn, "On", "Off"), , "SnapOn Example"
    ' Toggle the setting of SnapOn
    viewportObj.SnapOn = Not (viewportObj.SnapOn)
    ' Reset the active viewport to see the change on the AutoCAD status bar
    ThisDrawing.ActiveViewport = viewportObj
    MsgBox "Snap mode is now: " & IIf(viewportObj.SnapOn, "On", "Off"), , "SnapOn Example"
(defun c:Example_SnapOn()
    ;; This example toggles the setting of SnapOn.
    ;; Set the viewportObj variable to the activeviewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    ;; Display the current setting of SnapOn
    (alert (strcat "Snap mode is: " (if (= (vla-get-SnapOn viewportObj) :vlax-true) "On" "Off")))
    ;; Toggle the setting of SnapOn
    (vla-put-SnapOn viewportObj (if (= (vla-get-SnapOn viewportObj) :vlax-true) :vlax-false :vlax-true))
    ;; Reset the active viewport to see the change on the AutoCAD status bar
    (vla-put-ActiveViewport doc viewportObj)
    (alert (strcat "Snap mode is now: " (if (= (vla-get-SnapOn viewportObj) :vlax-true) "On" "Off")))
GMT+8, 2026-7-28 01:40
