ShadePlot 属性 (ActiveX)
指定视口的着色视口打印模式。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举AcShadePlot
言论没有其他评论。 例子VBA: Sub Example_ShadePlot()
' This example creates a paper space viewport,
' makes it active, and then sets it to plot as displayed.
Dim newPViewport As AcadPViewport
Dim height As Double
Dim width As Double
height = 30#
width = 40#
centerPoint(0) = 30#: centerPoint(1) = 30#: centerPoint(2) = 0#
' Create a paper space Viewport object
ThisDrawing.ActiveSpace = acPaperSpace
Set newPViewport = ThisDrawing.PaperSpace.AddPViewport(centerPoint, width, height)
ZoomAll
newPViewport.Display True
ThisDrawing.MSpace = True
' Set the viewport to plot as displayed
ThisDrawing.ActivePViewport = newPViewport
newPViewport.ShadePlot = acShadePlotAsDisplayed
可视化 LISP: (vl-load-com)
(defun c:Example_ShadePlot()
;; This example creates a paper space viewport,
;; makes it active, and then sets it to plot as displayed.
(setq centerPoint (vlax-3d-point 30 30 0)
width 40
height 40)
;; Create a paper space Viewport object
(vla-put-ActiveSpace doc acPaperSpace)
(setq paperSpace (vla-get-PaperSpace doc))
(setq newPViewport (vla-AddPViewport paperSpace centerPoint width height))
(vla-ZoomAll acadObj)
(vla-Display newPViewport :vlax-true)
(vla-put-MSpace doc :vlax-true)
;; Set the viewport to plot as displayed
(vla-put-ActivePViewport doc newPViewport)
(vla-put-ShadePlot newPViewport acShadePlotAsDisplayed)
GMT+8, 2026-11-15 12:13
