SegmentPerPolyline 属性 (ActiveX)
指定要为每条折线曲线生成的线段数。 支持的平台:仅限 Windows 属性值只读:不 类型:长 要为每条折线曲线生成的线段数。 0 < <= 42950SegmentPerPolyline 言论初始值为 8。指定的数字越大,对性能的影响就越大。 注意:此属性的值存储在 SPLINESEGS 系统变量中。
例子VBA: Sub Example_SegmentPerPolyline()
' SegmentPerPolyline. It then changes the value, and finally
Dim currSegmentPerPolyline As Integer
Dim newSegmentPerPolyline As Integer
' Retrieve the current SegmentPerPolyline value
currSegmentPerPolyline = ThisDrawing.preferences.SegmentPerPolyline
MsgBox "The current value for SegmentPerPolyline is " & currSegmentPerPolyline, vbInformation, "SegmentPerPolyline Example"
' Change the value for SegmentPerPolyline
newSegmentPerPolyline = 2001
ThisDrawing.preferences.SegmentPerPolyline = newSegmentPerPolyline
MsgBox "The new value for SegmentPerPolyline is " & newSegmentPerPolyline, vbInformation, "SegmentPerPolyline Example"
' Reset SegmentPerPolyline to its original value
ThisDrawing.preferences.SegmentPerPolyline = currSegmentPerPolyline
MsgBox "The SegmentPerPolyline value is reset to " & currSegmentPerPolyline, vbInformation, "SegmentPerPolyline Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SegmentPerPolyline()
;; SegmentPerPolyline. It then changes the value, and finally
(setq preferences (vla-get-Preferences doc))
;; Retrieve the current SegmentPerPolyline value
(setq currSegmentPerPolyline (vla-get-SegmentPerPolyline preferences))
(alert (strcat "The current value for SegmentPerPolyline is " (itoa currSegmentPerPolyline)))
;; Change the value for SegmentPerPolyline
(setq newSegmentPerPolyline 2001)
(vla-put-SegmentPerPolyline preferences newSegmentPerPolyline)
(alert (strcat "The new value for SegmentPerPolyline is " (itoa newSegmentPerPolyline)))
;; Reset SegmentPerPolyline to its original value
(vla-put-SegmentPerPolyline preferences currSegmentPerPolyline)
(alert (strcat "The SegmentPerPolyline value is reset to " (itoa currSegmentPerPolyline)))
GMT+8, 2026-10-26 18:15
