SCMTimeValue 属性 (ActiveX)
通过设置显示快捷菜单的长按持续时间来控制时间敏感的右键单击行为。 支持的平台:仅限 Windows 属性值只读:不 类型:长 介于 100 和 10,000 之间的数字(以毫秒为单位)。初始值为 250。 言论当该属性设置为 时,此属性会影响右键单击行为。SCMTimeModeTrue 注意:此属性的值存储在 SHORTCUTMENUDURATION 系统变量中。
例子VBA: Sub Example_SCMTimeValue()
' This example reads and modifies the SCMTimeValue property.
' Then the property is reset to its original value.
Dim ACADPref As AcadPreferencesUser
Dim originalValue As Integer, newValue As Integer
' Get the UserPreferences object and set the SCMTimeMode property to True
Set ACADPref = ThisDrawing.Application.Preferences.User
ACADPref.SCMTimeMode = True
originalValue = ACADPref.SCMTimeValue
MsgBox "The SCMTimeValue property is currently: " & originalValue
newValue = 1000
ACADPref.SCMTimeValue = newValue
MsgBox "The SCMTimeValue property has been set to: " & ACADPref.SCMTimeValue
ACADPref.SCMTimeValue = originalValue
MsgBox "The SCMTimeValue property was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_SCMTimeValue()
;; This example reads and modifies the SCMTimeValue property.
;; Then the property is reset to its original value.
;; Get the UserPreferences object and set the SCMTimeMode property to True
(vla-put-SCMTimeMode (vla-get-User preferences) :vlax-true)
(setq originalValue (vla-get-SCMTimeValue (vla-get-User preferences)))
(alert (strcat "The SCMTimeValue property is currently: " (itoa originalValue)))
(setq newValue 1000)
(vla-put-SCMTimeValue (vla-get-User preferences) newValue)
(alert (strcat "The SCMTimeValue property has been set to: " (itoa (vla-get-SCMTimeValue (vla-get-User preferences)))))
(vla-put-SCMTimeValue (vla-get-User preferences) originalValue)
(alert (strcat "The SCMTimeValue property was reset back to: " (itoa originalValue)))
GMT+8, 2026-11-20 17:48
