SCMCommandMode 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 572| 评论: 0|原作者: admin|来自: AutoCAD
确定在命令模式下在绘图区域中单击鼠标右键的功能,这意味着命令当前正在进行中。
object.SCMCommandMode
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:枚举AcDrawingAreaSCMCommand
  • acEnter:禁用命令快捷菜单。因此,在执行命令时在绘图区域中单击鼠标右键会发出 Enter。
  • acEnableSCM:启用命令快捷菜单。
  • acEnableSCMOptions:仅当命令行提示符中当前有可用选项时,才启用命令快捷菜单。在命令行提示符下,选项用方括号括起来。如果没有可用的选项,请右键单击问题 Enter。
此属性的初始值为 。acEnableSCMOptions
仅当该属性设置为 时,才能设置此属性。ShortcutMenuDisplayTrue
注意:此属性的值存储在 SHORTCUTMENU 系统变量中。
Sub Example_SCMCommandMode()
    ' This example reads and modifies the SCMCommandMode
    ' preference value.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesUser
    Dim originalValue As Integer, newValue As Integer
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.User
    originalValue = ACADPref.SCMCommandMode
    MsgBox "The SCMCommandMode preference is set to: " & originalValue
    ' Modify the SCMCommandMode preference by toggling the value
    ACADPref.SCMCommandMode = acEnter
    MsgBox "The SCMCommandMode preference has been set to: " & ACADPref.SCMCommandMode
    ACADPref.SCMCommandMode = originalValue
    MsgBox "The SCMCommandMode preference was reset back to: " & originalValue
(defun c:Example_SCMCommandMode()
    ;; This example reads and modifies the SCMCommandMode
    ;; preference value.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-SCMCommandMode (vla-get-User preferences)))
    (alert (strcat "The SCMCommandMode preference is set to: " (itoa originalValue)))
    ;; Modify the SCMCommandMode preference by toggling the value
    (vla-put-SCMCommandMode (vla-get-User preferences) acEnter)
    (alert (strcat "The SCMCommandMode preference has been set to: " (itoa (vla-get-SCMCommandMode (vla-get-User preferences)))))
    (vla-put-SCMCommandMode (vla-get-User preferences) originalValue)
    (alert (strcat "The SCMCommandMode preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-28 21:04
