ScaleLineweights 属性 (ActiveX)
指定打印布局时是否将线宽与几何图形的其余部分一起缩放。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论默认情况下,线宽以绝对大小(不缩放)打印。 为模型空间布局禁用该属性。 例子VBA: Sub Example_ScaleLineweights()
' This example reads and modifies the ScaleLineweights
' Layout value.
' When finished, this example resets the value back to
' its original value.
Dim ACADLayout As ACADLayout
Dim originalValue As Boolean
' Get the layout object
Set ACADLayout = ThisDrawing.ActiveLayout
originalValue = ACADLayout.ScaleLineweights
MsgBox "The ScaleLineweights value is set to: " & originalValue
' Modify the ScaleLineweights preference by toggling the value
ACADLayout.ScaleLineweights = Not ACADLayout.ScaleLineweights
MsgBox "The ScaleLineweights preference has been set to: " & ACADLayout.ScaleLineweights
ACADLayout.ScaleLineweights = originalValue
MsgBox "The ScaleLineweights preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_ScaleLineweights()
;; This example reads and modifies the ScaleLineweights
;; Layout value.
;; When finished, this example resets the value back to
;; its original value.
;; Get the layout object
(setq ACADLayout (vla-get-ActiveLayout doc))
(setq originalValue (vla-get-ScaleLineweights ACADLayout))
(alert (strcat "The ScaleLineweights value is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the ScaleLineweights preference by toggling the value
(vla-put-ScaleLineweights ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The ScaleLineweights preference has been set to: " (if (= (vla-get-ScaleLineweights ACADLayout) :vlax-true) "True" "False")))
(vla-put-ScaleLineweights ACADLayout originalValue)
(alert (strcat "The ScaleLineweights preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 14:17
