SavePreviewThumbnail 属性 (ActiveX)
指定是否将 BMP 预览图像与图形一起保存。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 注意:此属性的值保存在 THUMBSAVE 系统变量中。
例子VBA: Sub Example_SavePreviewThumbnail()
' SavePreviewThumbnail. It then changes the value, and finally
Dim currSavePreviewThumbnail As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current SavePreviewThumbnail value
currSavePreviewThumbnail = preferences.OpenSave.SavePreviewThumbnail
MsgBox "The current value for SavePreviewThumbnail is " & preferences.OpenSave.SavePreviewThumbnail, vbInformation, "SavePreviewThumbnail Example"
' Change the value for SavePreviewThumbnail
preferences.OpenSave.SavePreviewThumbnail = Not (currSavePreviewThumbnail)
MsgBox "The new value for SavePreviewThumbnail is " & preferences.OpenSave.SavePreviewThumbnail, vbInformation, "SavePreviewThumbnail Example"
' Reset SavePreviewThumbnail to its original value
preferences.OpenSave.SavePreviewThumbnail = currSavePreviewThumbnail
MsgBox "The SavePreviewThumbnail value is reset to " & currSavePreviewThumbnail, vbInformation, "SavePreviewThumbnail Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SavePreviewThumbnail()
;; SavePreviewThumbnail. It then changes the value, and finally
;; Retrieve the current SavePreviewThumbnail value
(setq currSavePreviewThumbnail (vla-get-SavePreviewThumbnail (vla-get-OpenSave preferences)))
(alert (strcat "The current value for SavePreviewThumbnail is " (if (= currSavePreviewThumbnail :vlax-true) "True" "False")))
;; Change the value for SavePreviewThumbnail
(vla-put-SavePreviewThumbnail (vla-get-OpenSave preferences) (if (= currSavePreviewThumbnail :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-SavePreviewThumbnail (vla-get-OpenSave preferences)))
(alert (strcat "The new value for SavePreviewThumbnail is " (if (= newValue :vlax-true) "True" "False")))
;; Reset SavePreviewThumbnail to its original value
(vla-put-SavePreviewThumbnail (vla-get-OpenSave preferences) currSavePreviewThumbnail)
(alert (strcat "The SavePreviewThumbnail value is reset to " (if (= currSavePreviewThumbnail :vlax-true) "True" "False")))
GMT+8, 2026-10-27 13:29
