Rows 属性 (ActiveX)
指定块数组或表中的行数。 支持的平台:仅限 Windows 属性值只读:不 类型:长 块数组或表中的行数。 言论没有其他评论。 例子VBA: Sub Example_Rows()
' This example creates a new MInsertBlock in the current drawing and
' displays the column and row information for the new MInsertBlock
Dim circleObj As AcadCircle
Dim centerPoint(0 To 2) As Double, InsertPoint(0 To 2) As Double
Dim radius As Double
Dim newMBlock As AcadMInsertBlock
Dim newBlock As AcadBlock
' Define the Circle object
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0
radius = 0.5
' Create a new block to hold the Circle
Set newBlock = ThisDrawing.Blocks.Add(centerPoint, "CBlock")
' Add the Circle object to the new block
Set circleObj = ThisDrawing.Blocks("CBlock").AddCircle(centerPoint, radius)
' Create a rectangular array of Circles using the new block containing the Circle
' and the AddMInsertBlock method
Set newMBlock = ThisDrawing.ModelSpace.AddMInsertBlock(InsertPoint, "CBlock", 1, 1, 1, 1, 2, 2, 1, 1)
' Display information about the Columns and Rows defined by the MInsertBlock
MsgBox "The new rectangular array is comprised of: " & vbCrLf & _
newMBlock.Columns & " columns with a spacing of " & newMBlock.ColumnSpacing & " and" & vbCrLf & _
newMBlock.Rows & " rows with a spacing of " & newMBlock.RowSpacing
可视化 LISP: (vl-load-com)
(defun c:Example_Rows()
;; This example creates a new MInsertBlock in the current drawing and
;; displays the column and row information for the new MInsertBlock
;; Define the Circle object
(setq centerPoint (vlax-3d-point 0 0 0)
InsertPoint (vlax-3d-point 1 1 0)
radius 0.5)
;; Create a new block to hold the Circle
(setq newBlock (vla-Add (vla-get-Blocks doc) centerPoint "CBlock"))
;; Add the Circle object to the new block
(setq circleObj (vla-AddCircle newBlock centerPoint radius))
;; Create a rectangular array of Circles using the new block containing the Circle
;; and the AddMInsertBlock method
(setq newMBlock (vla-AddMInsertBlock modelSpace InsertPoint "CBlock" 1 1 1 1 2 2 1 1))
(vla-ZoomAll acadObj)
;; Display information about the Columns and Rows defined by the MInsertBlock
(alert (strcat "The new rectangular array comprises: \n"
(itoa (vla-get-Columns newMBlock)) " columns with a spacing of " (rtos (vla-get-ColumnSpacing newMBlock) 2) " and\n"
(itoa (vla-get-Rows newMBlock)) " rows with a spacing of " (rtos (vla-get-RowSpacing newMBlock) 2) "."))
GMT+8, 2026-10-27 16:05
