Rotation 属性 (ActiveX)
指定对象的旋转角度。 支持的平台:仅限 Windows 签名VBA: object.Rotation
属性值只读:不 类型:Double(ACAD_ANGLE 类型的 OLE 对象除外) 以弧度为单位的旋转角度。 言论旋转角度相对于物体 WCS 的 X 轴,从 Z 轴向下看原点时,正角逆时针方向。 栅格:要以指定的旋转方式显示光栅图像,请将属性设置为 。ShowRotationTrue 文本:对于属性设置为 或 的文本,旋转角度是只读的。AlignmentacAlignmentAlignedacAlignmentFit ![]() 文本旋转角度 ![]() 尺寸线角度 例子VBA: Sub Example_Rotation()
' This example creates a text object in model space.
' It then changes the Rotation of the text object.
Dim textObj As AcadText
Dim textString As String
Dim height As Double
' Define the text object
textString = "Hello, World."
insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
height = 0.5
' Create the text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
ZoomAll
MsgBox "The Rotation is " & textObj.rotation, vbInformation, "Rotation Example"
' Change the value of the Rotation to 45 degrees (.707 radians)
textObj.rotation = 0.707
ZoomAll
MsgBox "The Rotation is set to " & textObj.rotation, vbInformation, "Rotation Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Rotation()
;; This example creates a text object in model space.
;; It then changes the Rotation of the text object.
;; Define the text object
(setq textString "Hello, World."
insertionPoint (vlax-3d-point 3 3 0)
height 0.5)
;; Create the text object in model space
(setq textObj (vla-AddText modelSpace textString insertionPoint height))
(vla-ZoomAll acadObj)
(alert (strcat "The Rotation is " (rtos (vla-get-Rotation textObj) 2)))
;; Change the value of the Rotation to 45 degrees (.707 radians)
(vla-put-Rotation textObj 0.707)
(alert (strcat "The Rotation is set to " (rtos (vla-get-Rotation textObj) 2)))
GMT+8, 2026-10-27 21:26
