RegisteredApplications 属性 (ActiveX)
获取文档的 RegisteredApplications 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_RegisteredApplications()
' This example finds the current RegisteredApplications collection and
' adds a new RegisteredApplication to that collection.
Dim RegAppColl As AcadRegisteredApplications
Set RegAppColl = ThisDrawing.RegisteredApplications
' Create a RegisteredApp named "TEST" in the current drawing
Dim RegAppObj As AcadRegisteredApplication
Set RegAppObj = RegAppColl.Add("TEST")
MsgBox "A new registered application called " & RegAppObj.name & " has been added to the Registered Applications collection.", vbInformation, "RegisteredApplications Example"
可视化 LISP: (vl-load-com)
(defun c:Example_RegisteredApplications()
;; This example finds the current RegisteredApplications collection and
;; adds a new RegisteredApplication to that collection.
(setq RegAppColl (vla-get-RegisteredApplications doc))
;; Create a RegisteredApp named "TEST" in the current drawing
(setq RegAppObj (vla-Add RegAppColl "TEST"))
(alert (strcat "A new registered application called " (vla-get-Name RegAppObj) " has been added to the Registered Applications collection."))
GMT+8, 2026-11-15 14:36
