RegenerateTableSuppressed 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 1258| 评论: 0|原作者: admin|来自: AutoCAD
启用或禁用表块的重新生成。
object.RegenerateTableSuppressed
类型: 表格
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止表的再生。
  • False:不禁止表的再生。
更改 Table 对象的所有方法都执行以下操作:
  1. 在写入模式下打开 Table 对象
  2. 根据输入参数修改 Table 对象
  3. 关闭 Table 对象,该对象将重新计算 Table
重新计算大型表会消耗大量时间和内存,因为对象是从头开始重建的。Table
为避免性能问题,在通过 API 修改大型表时,应暂时禁用对象的重新生成,然后应用修改并重新启用重新生成。Table
Sub Example_RegenerateTableSuppressed()
    Dim MyModelSpace As AcadModelSpace
    Dim MyTable As IAcadTable
    Dim pt(2) As Double
    Set MyModelSpace = ThisDrawing.ModelSpace
    Set MyTable = MyModelSpace.AddTable(pt, 100, 5, 5, 10)
    'Temporarily disable the recomputing of table block
    MyTable.RegenerateTableSuppressed = True
    Dim i As Integer, j As Integer
    For i = 0 To 99
        For j = 0 To 4
            Call MyTable.SetText(i, j, "my string " & i & ", " & j)
        Next j
    Next i
    'Now force the recomputing of table block
    'so that we can see the update table results
    MyTable.RegenerateTableSuppressed = False
    'You can also call RecomputeTableBlock(true) instead
    'to force the regeneration of table
    'MyTable.RecomputeTableBlock(True)
(defun c:Example_RegenerateTableSuppressed()
    (setq pt (vlax-3d-point 0 0 0))
    (setq MyModelSpace (vla-get-ModelSpace doc))
    (setq MyTable (vla-AddTable MyModelSpace pt 100 5 5 10))
    ;; Temporarily disable the recomputing of table block
    (vla-put-RegenerateTableSuppressed MyTable :vlax-true)
    (setq i 1
          j 0)
    (while (>= 99 i)
        (while (>= 4 j)
            (vla-SetText MyTable i j (strcat "my string " (itoa i) ", " (itoa j)))
            (setq j (1+ j))
        (setq i (1+ i)
              j 0)
    ;; Now force the recomputing of table block
    ;; so that we can see the update table results
    (vla-put-RegenerateTableSuppressed MyTable :vlax-false)
    ;; You can also call (vla-RecomputeTableBlock obj :vl;ax-true) instead
    ;; to force the regeneration of table
    ;;(vla-RecomputeTableBlock MyTable :vlax-true)
GMT+8, 2026-10-27 22:17
