ReadOnly 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 975| 评论: 0|原作者: admin|来自: AutoCAD
指定文档或属性是只读的还是读写的。
object.ReadOnly
类型:文档、DynamicBlockReferenceProperty
此属性应用于的对象。
只读:是的
类型:布尔
  • True:文档或属性是只读的。
  • False:文档或属性是可读写的。
Sub Example_ReadOnly()
    ' This example shows if current drawing file is read only or not
    If ThisDrawing.ReadOnly Then
        MsgBox "The current drawing file is read only.", , "ReadOnly Example"
    Else
        MsgBox "The current drawing file is read-write.", , "ReadOnly Example"
    End If
(defun c:Example_ReadOnly()
    ;; This example shows if current drawing file is read only or not
    (if (= (vla-get-ReadOnly doc) :vlax-true)
        (alert "The current drawing file is read only.")
        (alert "The current drawing file is read-write.")
GMT+8, 2026-10-31 12:48
