RadiusRatio 属性 (ActiveX)
指定椭圆的长轴与短轴之比。 支持的平台:仅限 Windows 属性值只读:不 类型:双 圆弧或圆的半径比。 言论如果输入的短轴长于长轴,则椭圆将为圆形,因为半径比不能大于 1.0。(半径比为 1.0 定义一个圆。 半径比 = 0.25 ![]() 半径比 = 0.75 例子VBA: Sub Example_RadiusRatio()
' This example creates an ellipse and finds the radius ratio
' for that ellipse. It then changes the radius ratio to 0.75.
Dim ellObj As AcadEllipse
Dim majAxis(0 To 2) As Double
Dim center(0 To 2) As Double
Dim radRatio As Double
' Create an ellipse in model space
center(0) = 5#: center(1) = 5#: center(2) = 0#
majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
radRatio = 0.3
Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
ZoomAll
MsgBox "This ellipse has a radius ratio of " & ellObj.RadiusRatio, vbInformation, "RadiusRatio Example"
' Change the radius ratio of the ellipse
radRatio = 0.75
ellObj.RadiusRatio = radRatio
ellObj.Update
MsgBox "The ellipse has been udpated with the radius ratio of " & ellObj.RadiusRatio, vbInformation, "RadiusRatio Example"
可视化 LISP: (vl-load-com)
(defun c:Example_RadiusRatio()
;; This example creates an ellipse and finds the radius ratio
;; for that ellipse. It then changes the radius ratio to 0.75.
;; Create an ellipse in model space
(setq center (vlax-3d-point 5 5 0)
majAxis (vlax-3d-point 10 20 0)
radRatio 0.3)
(setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
(vla-ZoomAll acadObj)
(alert (strcat "This ellipse has a radius ratio of " (rtos (vla-get-RadiusRatio ellObj) 2)))
;; Change the radius ratio of the ellipse
(vla-put-RadiusRatio ellObj 0.75)
(vla-Update ellObj)
(alert (strcat "The ellipse has been udpated with the radius ratio of " (rtos (vla-get-RadiusRatio ellObj) 2)))
GMT+8, 2026-10-26 12:22
