PrinterSpoolAlert 属性 (ActiveX)
指定当由于与 I/O 端口冲突而必须通过系统打印机对设备的输出进行假脱机处理时,是否向用户发出警报。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acPrinterSpoolAlert
言论此属性的初始值为 。acPrinterAlwaysAlert 例子VBA: Sub Example_PrinterSpoolAlert()
' This example reads and modifies the PrinterSpoolAlert
' preference value.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesOutput
Dim originalValue As Integer
' Get the user preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Output
originalValue = ACADPref.PrinterSpoolAlert
MsgBox "The PrinterSpoolAlert preference is set to: " & originalValue
' Modify the PrinterSpoolAlert preference by toggling the value
ACADPref.PrinterSpoolAlert = acPrinterNeverAlert
MsgBox "The PrinterSpoolAlert preference has been set to: " & ACADPref.PrinterSpoolAlert
ACADPref.PrinterSpoolAlert = originalValue
MsgBox "The PrinterSpoolAlert preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PrinterSpoolAlert()
;; This example reads and modifies the PrinterSpoolAlert
;; preference value.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PrinterSpoolAlert (vla-get-Output preferences)))
(alert (strcat "The PrinterSpoolAlert preference is set to: " (itoa originalValue)))
;; Modify the PrinterSpoolAlert preference by toggling the value
(vla-put-PrinterSpoolAlert (vla-get-Output preferences) acPrinterNeverAlert)
(alert (strcat "The PrinterSpoolAlert preference has been set to: " (itoa (vla-get-PrinterSpoolAlert (vla-get-Output preferences)))))
(vla-put-PrinterSpoolAlert (vla-get-Output preferences) originalValue)
(alert (strcat "The PrinterSpoolAlert preference was reset back to: " (itoa (vla-get-PrinterSpoolAlert (vla-get-Output preferences)))))
GMT+8, 2026-11-11 04:57
