PrinterPaperSizeAlert 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 793| 评论: 0|原作者: admin|来自: AutoCAD
指定在布局配置的纸张大小与 PC3 文件的默认设置不同时是否向用户发出警报。
object.PrinterPaperSizeAlert
类型:首选项输出
此属性应用于的对象。
只读:不
类型:布尔
  • True:提醒用户。
  • False:不提醒用户。
此属性的初始值为 。True
Sub Example_PrinterPaperSizeAlert()
    ' This example reads and modifies the PrinterPaperSizeAlert
    ' preference value.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesOutput
    Dim originalValue As Boolean
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Output
    originalValue = ACADPref.PrinterPaperSizeAlert
    MsgBox "The PrinterPaperSizeAlert preference is set to: " & originalValue
    ' Modify the PrinterPaperSizeAlert preference by toggling the value
    ACADPref.PrinterPaperSizeAlert = Not ACADPref.PrinterPaperSizeAlert
    MsgBox "The PrinterPaperSizeAlert preference has been set to: " & ACADPref.PrinterPaperSizeAlert
    ACADPref.PrinterPaperSizeAlert = originalValue
    MsgBox "The PrinterPaperSizeAlert preference was reset back to: " & originalValue
(defun c:Example_PrinterPaperSizeAlert()
    ;; This example reads and modifies the PrinterPaperSizeAlert
    ;; preference value.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PrinterPaperSizeAlert (vla-get-Output preferences)))
    (alert (strcat "The PrinterPaperSizeAlert preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PrinterPaperSizeAlert preference by toggling the value
    (vla-put-PrinterPaperSizeAlert (vla-get-Output preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The PrinterPaperSizeAlert preference has been set to: " (if (= (vla-get-PrinterPaperSizeAlert (vla-get-Output preferences)) :vlax-true) "True" "False")))
    (vla-put-PrinterPaperSizeAlert (vla-get-Output preferences) originalValue)
    (alert (strcat "The PrinterPaperSizeAlert preference was reset back to: " (if (= (vla-get-PrinterPaperSizeAlert (vla-get-Output preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-28 00:04
