PrimaryUnitsPrecision 属性 (ActiveX)
指定为尺寸或公差的主要单位显示的小数位数。 支持的平台:仅限 Windows 签名VBA: object.PrimaryUnitsPrecision
属性值只读:不 类型:枚举acDimPrecision
言论注意:此属性将覆盖给定维度的 DIMDEC 系统变量的值。
例子VBA: Sub Example_PrimaryUnitsPrecision()
' uses PrimaryUnitsPrecision to allow the user to change
' the number of decimal places displayed for the primary units and tolerance
' units of the dimension.
Dim dimObj As AcadDimAligned
Dim oldPrecision As String, newPrecision As String
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
' Enable and setup tolerance display
dimObj.ToleranceDisplay = acTolSymmetrical
dimObj.ToleranceLowerLimit = -0.0001
dimObj.ToleranceUpperLimit = 0.005
' Store old precision value as default for input box
oldPrecision = dimObj.PrimaryUnitsPrecision
' Allow the user to change the precision for the dimension and dimension tolerance
newPrecision = InputBox("Enter a new precision for the dimension and tolerances. The value must range from 0 to 8.", "Change Precision", oldPrecision)
Select Case newPrecision
Case 0: newPrecision = acDimPrecisionZero
Case 1: newPrecision = acDimPrecisionOne
Case 2: newPrecision = acDimPrecisionTwo
Case 3: newPrecision = acDimPrecisionThree
Case 4: newPrecision = acDimPrecisionFour
Case 5: newPrecision = acDimPrecisionFive
Case 6: newPrecision = acDimPrecisionSix
Case 7: newPrecision = acDimPrecisionSeven
Case 8: newPrecision = acDimPrecisionEight
Case Else
MsgBox "The precision has not been changed."
Exit Sub
End Select
' Change the dimension and tolerance precision
dimObj.TolerancePrecision = newPrecision
dimObj.PrimaryUnitsPrecision = newPrecision
' Read back and display the dimension and dimension tolerance precision
newPrecision = dimObj.PrimaryUnitsPrecision
MsgBox "The precision has been set to " & newPrecision & " decimal places"
可视化 LISP: (vl-load-com)
(defun c:Example_PrimaryUnitsPrecision()
;; uses PrimaryUnitsPrecision to allow the user to change
;; the number of decimal places displayed for the primary units and tolerance
;; units of the dimension.
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5.12345678 5 0)
;; Enable and setup tolerance display
(vla-put-ToleranceDisplay dimObj acTolSymmetrical)
(vla-put-ToleranceLowerLimit dimObj -0.0001)
(vla-put-ToleranceUpperLimit dimObj 0.005)
(vla-ZoomAll acadObj)
;; Store old precision value as default for input box
(setq oldPrecision (vla-get-PrimaryUnitsPrecision dimObj))
;; Allow the user to change the precision for the dimension and dimension tolerance
(setq newPrecision (vla-GetInteger (vla-get-Utility doc) "\nEnter a new precision for the dimension and tolerances (0 - 8): "))
(setq newPrecision (cond
((= 0 newPrecision) acDimPrecisionZero)
((= 1 newPrecision) acDimPrecisionOne)
((= 2 newPrecision) acDimPrecisionTwo)
((= 3 newPrecision) acDimPrecisionThree)
((= 4 newPrecision) acDimPrecisionFour)
((= 5 newPrecision) acDimPrecisionFive)
((= 6 newPrecision) acDimPrecisionSix)
((= 7 newPrecision) acDimPrecisionSeven)
((= 8 newPrecision) acDimPrecisionEight)
(nil)
;; Change the dimension and tolerance precision
(if (/= newPrecision nil)
(progn
(vla-put-TolerancePrecision dimObj newPrecision)
(vla-put-PrimaryUnitsPrecision dimObj newPrecision)
;; Read back and display the dimension and dimension tolerance precision
(setq newPrecision (vla-get-PrimaryUnitsPrecision dimObj))
(alert (strcat "The precision has been set to " (itoa newPrecision) " decimal places"))
(alert "The precision has not been changed.")
GMT+8, 2026-10-30 22:49
