PlotWithLineweights 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 805| 评论: 0|原作者: admin|来自: AutoCAD
指定对象是使用打印文件中指定的线宽进行打印,还是使用图形文件中的线宽进行打印。
object.PlotWithLineweights
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:布尔
  • True:使用绘图样式中的线宽进行绘图。
  • False:使用图形文件中的线宽进行打印。
Sub Example_PlotWithLineweights()
    ' This example reads and modifies the PlotWithLineweights
    ' Layout value.
    ' When finished, this example resets the  value back to
    ' its original value.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Boolean
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.PlotWithLineweights
    MsgBox "The PlotWithLineweights value is set to: " & originalValue
    ' Modify the PlotWithLineweights preference by toggling the value
    ACADLayout.PlotWithLineweights = Not ACADLayout.PlotWithLineweights
    MsgBox "The PlotWithLineweights preference has been set to: " & ACADLayout.PlotWithLineweights
    ACADLayout.PlotWithLineweights = originalValue
    MsgBox "The PlotWithLineweights preference was reset back to: " & originalValue
(defun c:Example_PlotWithLineweights()
    ;; This example reads and modifies the PlotWithLineweights
    ;; Layout value.
    ;; When finished, this example resets the  value back to
    ;; its original value.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-PlotWithLineweights ACADLayout))
    (alert (strcat "The PlotWithLineweights value is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PlotWithLineweights preference by toggling the value
    (vla-put-PlotWithLineweights ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PlotWithLineweights ACADLayout))
    (alert (strcat "The PlotWithLineweights preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    (vla-put-PlotWithLineweights ACADLayout originalValue)
    (alert (strcat "The PlotWithLineweights preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-28 16:10
