PlotType 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 952| 评论: 0|原作者: admin|来自: AutoCAD
指定布局或打印配置的类型。
object.PlotType
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:枚举acPlotType
  • acDisplay:打印当前显示器中的所有内容。
  • acExtents:打印当前所选空间范围内的所有内容。
  • acLimits:打印当前空间限制内的所有内容。
  • acView:打印由属性命名的视图。ViewToPlot
  • acWindow:打印方法指定的窗口中的所有内容。SetWindowToPlot
  • acLayout:打印指定纸张尺寸边距内的所有内容,原点从“布局”选项卡中的 0,0 坐标位置计算。从模型空间打印时,此选项不可用。
在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen
必须先调用该属性或方法,然后才能将 设置为 或 。ViewToPlotSetWindowToPlotPlotTypeacViewacWindow
Sub Example_PlotType()
    ' This example reads and modifies the PlotType
    ' Layout value.
    ' When finished, this example resets the  value back to
    ' its original value.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Integer
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.PlotType
    MsgBox "The PlotType value is set to: " & originalValue
    ' Modify the PlotType preference by toggling the value
    ACADLayout.PlotType = acExtents
    MsgBox "The PlotType preference has been set to: " & ACADLayout.PlotType
    ACADLayout.PlotType = originalValue
    MsgBox "The PlotType preference was reset back to: " & originalValue
(defun c:Example_PlotType()
    ;; This example reads and modifies the PlotType
    ;; Layout value.
    ;; When finished, this example resets the  value back to
    ;; its original value.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-PlotType ACADLayout))
    (alert (strcat "The PlotType value is set to: " (itoa originalValue)))
    ;; Modify the PlotType preference by toggling the value
    (vla-put-PlotType ACADLayout acExtents)
    (alert (strcat "The PlotType preference has been set to: " (itoa (vla-get-PlotType ACADLayout))))
    (vla-put-PlotType ACADLayout originalValue)
    (alert (strcat "The PlotType preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-27 21:20
