PlotRotation 属性 (ActiveX)
指定布局或打印配置的旋转角度。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acPlotRotation
言论旋转角度相对于物体 WCS 的 X 轴,从 Z 轴向下看原点时,正角逆时针方向。 在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen 例子VBA: Sub Example_PlotRotation()
' This example reads and modifies the PlotRotation
' Layout value.
' When finished, this example resets the value back to
' its original value.
Dim ACADLayout As ACADLayout
Dim originalValue As Integer
' Get the layout object
Set ACADLayout = ThisDrawing.ActiveLayout
originalValue = ACADLayout.PlotRotation
MsgBox "The PlotRotation value is set to: " & originalValue
' Modify the PlotRotation preference by toggling the value
ACADLayout.PlotRotation = ac180degrees
MsgBox "The PlotRotation preference has been set to: " & ACADLayout.PlotRotation
ACADLayout.PlotRotation = originalValue
MsgBox "The PlotRotation preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PlotRotation()
;; This example reads and modifies the PlotRotation
;; Layout value.
;; When finished, this example resets the value back to
;; its original value.
;; Get the layout object
(setq ACADLayout (vla-get-ActiveLayout doc))
(setq originalValue (vla-get-PlotRotation ACADLayout))
(alert (strcat "The PlotRotation value is set to: " (itoa originalValue)))
;; Modify the PlotRotation preference by toggling the value
(vla-put-PlotRotation ACADLayout ac180degrees)
(alert (strcat "The PlotRotation preference has been set to: " (itoa (vla-get-PlotRotation ACADLayout))))
(vla-put-PlotRotation ACADLayout originalValue)
(alert (strcat "The PlotRotation preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-27 22:03
