PlotOrigin 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 735| 评论: 0|原作者: admin|来自: AutoCAD
在 WCS 坐标中指定布局或打印配置的原点。
object.PlotOrigin
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:变体(双精度的双元素数组)
X 和 Y 值表示相对于媒体左下角的原点。
原点与介质边缘的偏移量为纸张边距。使用该方法查询边距。原点以毫米为单位。GetPaperMargins
在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen
Sub Example_PlotOrigin()
    ' This example reads and modifies the PlotOrigin
    ' Layout value.
    ' When finished, this example resets the  value back to
    ' its original value.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Variant
    Dim newValue(0 To 1) As Double
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.PlotOrigin
    MsgBox "The PlotOrigin value is set to: " & originalValue(0) & " ," & originalValue(1)
    ' Modify the PlotOrigin preference by toggling the value
    newValue(0) = originalValue(0) + 20
    newValue(1) = originalValue(1) - 20
    ACADLayout.PlotOrigin = newValue
    MsgBox "The PlotOrigin value is set to: " & newValue(0) & " ," & newValue(1)
    ACADLayout.PlotOrigin = originalValue
(defun c:Example_PlotOrigin()
    ;; This example reads and modifies the PlotOrigin
    ;; Layout value.
    ;; When finished, this example resets the  value back to
    ;; its original value.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vlax-variant-value (vla-get-PlotOrigin ACADLayout)))
    (alert (strcat "The PlotOrigin value is set to: " (rtos (vlax-safearray-get-element originalValue 0) 2) " ,"
                                                      (rtos (vlax-safearray-get-element originalValue 1) 2)))
    ;; Modify the PlotOrigin preference by toggling the value
    (setq newValue (vlax-make-safearray vlax-vbDouble '(0 . 1)))
    (vlax-safearray-fill newValue (list (+ (vlax-safearray-get-element originalValue 0) 20)
                                        (- (vlax-safearray-get-element originalValue 1) 20)))
    (vla-put-PlotOrigin ACADLayout newValue)
    (alert (strcat "The PlotOrigin value is set to: " (rtos (vlax-safearray-get-element newValue 0) 2) " ,"
                                                      (rtos (vlax-safearray-get-element newValue 1) 2)))
    (vla-put-PlotOrigin ACADLayout originalValue)
GMT+8, 2026-10-27 13:30
