PlotConfigurations 属性 (ActiveX)
获取文档的 PlotConfigurations 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_PlotConfigurations()
' This example will access the PlotConfigurations collection for the current drawing,
' add a plot configuration, and list basic information about the
' plot configurations in the drawing.
Dim PlotConfigurations As AcadPlotConfigurations
Dim PlotConfiguration As AcadPlotConfiguration
Dim msg As String
' Get PlotConfigurations collection from document object
Set PlotConfigurations = ThisDrawing.PlotConfigurations
' If there aren't any plot configurations, then add one
If PlotConfigurations.count = 0 Then
'*** Customize the new configuration to your satisfaction ***
PlotConfigurations.Add "NEW_CONFIGURATION"
End If
msg = vbCrLf ' Start with a space
' Get the names of the plot configurations in this drawing
For Each PlotConfiguration In PlotConfigurations
msg = msg & PlotConfiguration.name & vbCrLf
Next
' Display a list of available plot configurations
MsgBox "There are " & PlotConfigurations.count & " plot configuration(s) in " & _
ThisDrawing.WindowTitle & ":" & msg
可视化 LISP: (vl-load-com)
(defun c:Example_PlotConfigurations()
;; This example will access the PlotConfigurations collection for the current drawing,
;; add a plot configuration, and list basic information about the
;; plot configurations in the drawing.
;; Get PlotConfigurations collection from document object
(setq PlotConfigurations (vla-get-PlotConfigurations doc))
;; If there aren't any plot configurations, then add one
(if (= (vla-get-Count PlotConfigurations) 0)
;; *** Customize the new configuration to your satisfaction ***
(vla-Add PlotConfigurations "NEW_CONFIGURATION")
(setq msg "")
;; Get the names of the plot configurations in this drawing
(vlax-for PlotConfiguration PlotConfigurations
(setq msg (strcat msg (vla-get-Name PlotConfiguration) "\n"))
;; Display a list of available plot configurations
(alert (strcat "There are " (itoa (vla-get-Count PlotConfigurations)) " plot configuration(s) in "
(vla-get-WindowTitle doc) ": \n" msg))
GMT+8, 2026-10-30 09:03
